cleaning the engine
Old Aug 6, 2011 | 11:20 AM
kjwinston's Avatar
Default cleaning the engine
What is a good spray or cleaner to use before hosing down the engine. Any thoughts of a good product(s) here? My engine is starting to get dusty.
Kj
Old Aug 6, 2011 | 12:54 PM
maxcichon's Avatar
Default Re: cleaning the engine
https://www.crossfireforum.org/forum...crossfire.html
Old Aug 6, 2011 | 06:48 PM
IBLUBYU's Avatar
Kj
Simple Green
Old Aug 7, 2011 | 10:50 AM
kjwinston's Avatar
Thxfor the Info, I printed it into a log book. Simple green, wow would never had thought that. Must cut into road ware pretty good. Thanks again.
Kj
Old Aug 7, 2011 | 11:41 AM
maxcichon's Avatar
Sorry I was so short with my answer-you were the 4th person to ask that in the last week.
50% strength on the Simple Green dilution.
Old Aug 8, 2011 | 07:16 PM
kjwinston's Avatar
Is simple green a grease remover? Will it remove road dust and tar?
Kj
Old Aug 8, 2011 | 07:56 PM
maxcichon's Avatar
It will remove everything you want it to. It is quite effective.
Yes, it is a de-greaser.
Old Aug 9, 2011 | 06:37 AM
Or 50/50 water and 'Greased Lightning'
Been using that for about 10 years.
DO NOT USE FULL STRENGTH - IT WILL DISCOLOR PLASTIC.
Don't leave it on more than 2-3 minutes before rinsing thoroughly.
Old Mar 5, 2012 | 11:42 PM
jsmith14's Avatar
Banned
I will make the assumption you want to do this while the engine is in the vehicle. This is a good idea, helps your engine cool off more efficiently and you will get better gas mileage and possibly a few more horsepower. First off, disconnect your battery negative terminal first then cover your alternator in plastic and tape. Make sure your alternator is completely sealed in. Use engine degreaser available at most part stores ) to spray the block and engine components. Read the instructions and warnings on the degreaser, some are bad for rubber parts ( such as fuel lines, electrical wire insulation and spark plug wire insulation ) and take the necessary precautions. Let the degreaser do it's job by waiting the prescribed length of time listed on the degreaser can. Then hose off the block. You will probably have to use some rags and elbow grease to get off all of the gunk. Dispose of the refuse in a legal manner and once your motor is completely dry, take off the cover on your alternator and reconnect your battery.for more info about auto repair for cleaning engine you can look more on the site.
Old Mar 6, 2012 | 12:13 AM
Originally Posted by IBLUBYU
Simple Green
Yup
50/50 mix of Simple Green and water.
Spray on cool engine and all surfaces avoiding electrical devices.
Allow to set for about 10 minutes
Rinse thoroughly with clean water and start the engine.
Drive around for awhile and heat up the engine to ensure it is dry.
Then spray all surfaces with CD-2 Engine Detailer once again avoiding belts and electrical devices.
Here is mine after this procedure
Old Mar 11, 2012 | 07:52 PM
coolx's Avatar
Just my two cents worth: your engine looks really....really nice - great job!
Old Mar 12, 2012 | 11:25 AM
STEPHENJXN's Avatar
Wow. Do you ever DRIVE this car? The engine looks brand new!
Old Mar 12, 2012 | 11:16 PM
Yes almost everyday throughout the spring, summer and fall.
I have put 60,000 miles on that engine since April 2007.
I just keep up with the detailing and I like the results.
Old Mar 13, 2012 | 01:45 AM
lildaddym's Avatar
What do you guys use to clean that aluminum?
Old Jun 2, 2012 | 10:34 AM
red-in-la
Guest
Posts: n/a
Use a leaf blower to dry off the engine. I've been using one for years. It gets all the water out of electrical connections and there is no water pooling anywhere.
On previous 4 cyl, twin cam engines water always got down into the spark plug holes. The leaf blower is perfect to clear out water like that.
Old Jun 2, 2012 | 10:56 AM
Valk, you have MY engine !!!!! - see my gallery
Old Jun 2, 2012 | 10:59 AM
Been using leaf blowers on my engines ( all of 'em, cars, trucks, lawnmowers, motorcycles, airplanes ) since 1975.
I'm on my fifth leaf blower .... ( this last one just doesn't seem to want to quit, I've had it since '97 - Lawn Boy )
Old Sep 13, 2012 | 05:50 AM
user 72983's Avatar
Banned
Removed engine cover to clean/recharge K&N's
I want to clean he inside of the cover, tubes, filter box.
Recommended? Or just wipe it down?
Simple green or other solution? Soap and water?
Thanks
Old Sep 13, 2012 | 07:28 AM
maxcichon's Avatar
I would use the same Simple Green 50/50 mix and a long brush. I did that once when I had the OEM fifter box and it worked great. Oh-my box was custom painted too! No problemo.
Old Sep 23, 2012 | 04:21 PM
Simple Green at 1/1 (probably 1/5 would work) does a fantastic job on the windows of the house, that's my 2 centavos.
Beats the other stuff hands down.
