any way to treat/protect rubber?
Old Aug 24, 2011 | 04:14 PM
killerkanadian's Avatar
Default any way to treat/protect rubber?
As I'm sure all of you know, after a car gets a couple years on its body the black on the rubber begins to smear off onto the paint. What have you guys found to help with this problem?
Old Aug 29, 2011 | 01:41 PM
Goldwing's Avatar
Default Re: any way to treat/protect rubber?
Are you talking the rubber and road tar that get thrown up behind the wheel wells? I have used bug/tar remover but find that WD-40 does just as good a job as a solvent. Then wash well and wax.
Old Aug 29, 2011 | 03:55 PM
Nah, im talking about the rubber that goes around your windows and stuff. It always streaks black onto your cars.
Old Aug 29, 2011 | 04:08 PM
I use the Meguiars product for this.
Old Aug 29, 2011 | 04:12 PM
Something like this?
MeguiarsDirect.com: Mirror Glaze Vinyl & Rubber Cleaner
Old Aug 29, 2011 | 07:07 PM
Toolman's Avatar
The problem is the rubber is degrading. To protect the rubber I apply a very thin coat of silicone grease.
Old Aug 29, 2011 | 08:39 PM
04Fire's Avatar
Exactly what I use. Notice how that bottle has a "40" on it... you also want to get the same looking bottle with "39" on it. Then use in numerical order... the "39" is the deep cleaner and the "40" is the UV protector/shine.
I've been using it for years and all my rubber looks and feels like new.
Old Aug 29, 2011 | 08:45 PM
acrispy1's Avatar
I've tried a lot of different products. I now only use Adam's In & Out Spray Dressing
Old Aug 29, 2011 | 08:53 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
The person that writes these product desriptions must be having a chuckle :
Get 's into Tight Areas with Ease
Go from Boring to Brilliant FAST
Old Aug 29, 2011 | 09:19 PM
Tell your new girlfriends parents you use it all the time.
Old Aug 29, 2011 | 10:09 PM
Thanks for the help fellas
Old Aug 30, 2011 | 07:43 AM
UK_Mouldy's Avatar
If you are looking for something to re-condition door and window seals, this is ideal;
Einszett Gummi Pflege / Rubber Care Stick - 100ml | eBay
I'm not sure that I would use it on external rubber, such as bump strips along the doors, etc. I use AutoGlym Bumper Care for that;
Autoglym Bumper Care (325ml) | eBay
Hope that helps!!!
Old Aug 30, 2011 | 09:12 PM
FIXRE's Avatar
Any suggestions for the black plastic bordering the bottom exterior of the windshield? The area where the wipers are mounted. Although I keep my car covered, this is the only area that shows fading or uv damage.
Old Aug 31, 2011 | 09:28 PM
I bought some Mothers Back-to-Black which looks like it can be used on just about anything black. It worked great on my rubber sills.
http://www.mothers.com/02_products/06108.html
I would of went with the meguires for this job but this is all autozone carried and im an impatient kind of guy.
Edit: I put it on the plastic front corner as i was doing the rubber, and it seemed to work well.
Old Sep 1, 2011 | 03:05 PM
Mike-in-Orange's Avatar
For rubber weather seals go with Meguiar's M40 (we've had long time users of Gummi Pflege say they prefer M40) and for the plastic cowling at the base of the windshield go with Meguiar's Ultimate Protectant or Ultimate Black (same basic product, but one's in a trigger spray one's in lotion form).
Application process is different for the two, though. For M40 you want to put it on fairly heavy, let it dwell for a while and then wipe off the excess. For the Ultimate Protectant/Black you want to apply a very small amount with a foam wax applicator pad, working it in very thoroughly. It will deep clean and restore the faded plastic. If you have to come back and wipe off any excess, you used way too much. It will dry totally dry to the touch if you apply it right.
Both of these are water based products, but the Ultimate product has polymers in it that allow it to bond to plastic and vinyl trim much the same way a sealant bonds to your paint.
Old Sep 1, 2011 | 06:17 PM
FIXRE's Avatar
Thanks guys.
PimpDaddy
Sep 29, 2016 11:55 PM
o55ie18
Oct 5, 2015 05:50 PM
waldig
Sep 17, 2015 10:35 AM
blackpepper
Aug 31, 2015 12:18 PM
ala_xfire
Aug 16, 2015 09:45 PM
