any way to treat/protect rubber?
As I'm sure all of you know, after a car gets a couple years on its body the black on the rubber begins to smear off onto the paint. What have you guys found to help with this problem?
Are you talking the rubber and road tar that get thrown up behind the wheel wells? I have used bug/tar remover but find that WD-40 does just as good a job as a solvent. Then wash well and wax.
Originally Posted by killerkanadian
Nah, im talking about the rubber that goes around your windows and stuff. It always streaks black onto your cars.
Something like this?
MeguiarsDirect.com: Mirror Glaze Vinyl & Rubber Cleaner
I've been using it for years and all my rubber looks and feels like new.
I've tried a lot of different products. I now only use Adam's In & Out Spray Dressing
Get 's into Tight Areas with Ease
Go from Boring to Brilliant FAST
The person that writes these product desriptions must be having a chuckle :
If you are looking for something to re-condition door and window seals, this is ideal;
Einszett Gummi Pflege / Rubber Care Stick - 100ml | eBay
I'm not sure that I would use it on external rubber, such as bump strips along the doors, etc. I use AutoGlym Bumper Care for that;
Autoglym Bumper Care (325ml) | eBay
Hope that helps!!!
Hope that helps!!!
Any suggestions for the black plastic bordering the bottom exterior of the windshield? The area where the wipers are mounted. Although I keep my car covered, this is the only area that shows fading or uv damage.
http://www.mothers.com/02_products/06108.html
I would of went with the meguires for this job but this is all autozone carried and im an impatient kind of guy.
Edit: I put it on the plastic front corner as i was doing the rubber, and it seemed to work well.
For rubber weather seals go with Meguiar's M40 (we've had long time users of Gummi Pflege say they prefer M40) and for the plastic cowling at the base of the windshield go with Meguiar's Ultimate Protectant or Ultimate Black (same basic product, but one's in a trigger spray one's in lotion form).
Application process is different for the two, though. For M40 you want to put it on fairly heavy, let it dwell for a while and then wipe off the excess. For the Ultimate Protectant/Black you want to apply a very small amount with a foam wax applicator pad, working it in very thoroughly. It will deep clean and restore the faded plastic. If you have to come back and wipe off any excess, you used way too much. It will dry totally dry to the touch if you apply it right.
Both of these are water based products, but the Ultimate product has polymers in it that allow it to bond to plastic and vinyl trim much the same way a sealant bonds to your paint.
o55ie18
Oct 5, 2015 05:50 PM
blackpepper
Aug 31, 2015 12:18 PM
