brake light turning on headlight???
Recently my main headlights will not turn on and my brake pedal turns on my running light in my headlights only on one side. The fuses are fine and I recently had my main wire harness and my ECU replaced. According to the dealer those replacements have nothing to do with the issues. I am having a hard time believing that seeing that the brake wiring and headlight wiring should be circuited together. Has anyone had an issue like this? Am I getting screwed? If you could help thanks.
I have seen strange problems when a ground connection comes loose. The ones that are screwed to the body and often have more than one wire.
Pull the fuse for the brake light and see what changes.
I know of a case back in 2004 when Chrysler couldn't fix a problem like that. They got a MB rep to look at it after replacing many parts. He said change the headlight switch. That fixed the problem....
Roty135
17
Oct 11, 2018 10:11 AM
PNA
Jul 27, 2015 12:28 PM
