rear lighting
Old Oct 18, 2011 | 09:41 AM
Brendon2022's Avatar
Default rear lighting
what do i need to replace my rear tail light that is cracked? do i need to buy the whole tailight or do i buy a cover, tail lamp assay, wiring harness? can someone explain to me what the parts are?
Old Oct 18, 2011 | 10:10 AM
JHM2K's Avatar
Default Re: rear lighting
The whole assembly needs to be replaced.
Remove the bulbs, and keep those... Search ebay/LKQ for a tail light assembly.
New ones at the dealer are $$$$
Old Oct 18, 2011 | 10:55 AM
Depending on whether you wish this to be a show car, or a daily driver, you might want to check into X-Pel Technologies protectant film. They will sell it by the sq inch, probably around $50 for enough to cover both tail lights. ( I couldn't find a pre-cut set for the tail lights )
( assuming you are a DIY type )
XPEL Technologies Corp.: Paint & Headlamp Protection Material By The Foot
look under the headlight protector category and measure how much you will need to cover both tail lights.
Old Oct 18, 2011 | 11:01 AM
damn, i was hoping to only be able to replace the plastic cover which is the one that is cracked the fog lamps are also cracked and those are expensive also
Old Oct 18, 2011 | 11:13 AM
I have considered doing this also, I was thinking about adding a tinted color to try and cover up the crack. would a tint look ok?
Old Oct 18, 2011 | 11:55 AM
I have seen tinted tail lights on a couple of the black cars - don't look too bad ...
Not quite sure just how legal it is, however. Best check your state laws .....
PNA
Nov 12, 2020 04:44 PM
Hoppy
Dec 7, 2018 07:36 AM
axnguyen
Jul 21, 2015 11:41 AM
mike28117
Jul 17, 2015 01:59 PM
KwehCat
Jul 16, 2015 04:48 PM
