Standing/Parking Lights
Old Jul 14, 2004 | 09:43 AM
goat's Avatar
Default Standing/Parking Lights
I switched over the high and low beam headlights and foglights to Silverstars, and now I'd like to change the standing/parking lights to the same...for color match so it's consistent over the whole front end...does anyone know the sylvania part number I should use? The owner's manual says those bulbs are W5W, but i can't seem to find a way to cross reference this to a Sylvania number.
Old Jul 14, 2004 | 12:15 PM
David Burns's Avatar
Default
You could try these:
Philips Blue Vision Sidelights W5W
At last we have matching colour temperature in the zone of HID (High Intensity Discharge) and H1 H4/H7 lamps, for a whiter and homogeneous light.This is the end of the yellowish position lamp/city lights.
High colour temperature of light (3300 K)
Xenon gas filling
Coated with a high temperature resistant varnish
Cooler and bluer light
Colour perfect fitting with H1 H4/H7 and HID lamps
Extended lifetime ,twice as long as regular sidelights
These bulbs are sold in packs of 2 bulbs
http://www.powerbulbs.com/products/p...=pbvs&type=W5W
Old Jul 14, 2004 | 12:18 PM
goat's Avatar
Default
thanks david...in looking around some more, i think that's what i'm going to get. sounds like the color should be close...
Old Jul 14, 2004 | 12:31 PM
Default
I saw some place on the web the other day that was offering a free set of those W5W bulbs if you bought a set of SilverStar's, but I can't find 'em today.
Old Jul 14, 2004 | 12:35 PM
goat's Avatar
Default
i saw that too. however, i got all my silverstars from walmart, who was $3 to $5 cheaper than anywhere else, which is more than enough to cover the cost of a pair of W5Ws.
Old Jul 14, 2004 | 04:18 PM
Default
Cool. I bought mine at WalMart too...
If you can, shoot some before/after pics of the W5W install. I might go ahead with this mod too.
Old Jul 14, 2004 | 04:22 PM
goat's Avatar
Default
if i can find them local, i will do that soon. stopped at walmart and the nearby autozone at lunch today and neither had the Phillips Blue Vision...
Old Jul 16, 2004 | 12:36 PM
bmerfan's Avatar
Default
I've just purhcased some white LED types from PIAA, but! installing them is a nightmare as the whole headlamp unit has to be removed... unless you guys tell me differant..
Old Jul 21, 2004 | 02:27 PM
XfireAce's Avatar
Default
Does the whole headlamp have to be removed to replace these bulbs?
Old Jul 21, 2004 | 04:34 PM
goat's Avatar
Default
i hope not. waiting for mine to get here. just got a set off ebay. will let you know when i try!
Old Aug 5, 2004 | 10:01 PM
REDCROSS's Avatar
Honorary -C-I-C-C-I Member
Default
SSSSSsssssoooooooooooooo..................
What happened????
Pull the headlamp or get a female with long thin fingers to replace the bulbs??? :roll:
Old Aug 6, 2004 | 08:20 AM
FerrariVdub's Avatar
Default Put mine in
I put my parking lights in without taking out the headlight it driver side wasnt too bad but the passinger side was a *****. Took a little while, used a long needle nose pliers and then twisted it out the put it back in and twistd it in. I used the 5 led lights and they look good.
Old Aug 6, 2004 | 08:24 AM
goat's Avatar
Default
i did pull the headlamp assembly. made it easier to get at the bulbs, but the mounting bolts for the assembly that are waaay underneath were kind of a pain...so it may be a horse apiece doing it either way. my guess would be a little easier to take out the whole assembly.
Old Aug 6, 2004 | 10:02 PM
REDCROSS's Avatar
Default
I can't find a source (in the USA) for the Phillips City lights anywhere.
Help on that anyone??
Old Aug 9, 2004 | 08:36 AM
goat's Avatar
Default
I couldn't either. I was going to order from Powerbulbs.com (I read that people were having no problems ordering from them, though the are in the UK), but i got lucky and found a set on Ebay.
Old Aug 11, 2004 | 09:34 PM
dsxfire's Avatar
Default
i put piaa h7 low beams in mine and also piaa 9006 fog lights both having 4000 kelvin white light with a blue tint they look awsome just like hid but a little pricy. $85 a set. But well worth it
Old Sep 18, 2004 | 02:57 AM
MadRooster's Avatar
Default
I know this thread has been dead for a while but I found this alternative to powerbulbs.com:
http://www.ambulbs.com
It's not as cheap as powerbulbs (i.e. not free) but it's in the U.S.
Also, the only place I found online that carried the sylvania turn signals (7057st) was the store on the Sylvania site. I'm know there are others but I didn't take note of them because they don't ship to Hawaii.
Old Sep 18, 2004 | 05:32 AM
REDCROSS's Avatar
Default
Believe it or not I have a pastie on my computer as a reminder for the Phillips W5W that I have never found................................
And now, through you, I have!!!!!!!!!!!!!!!!!!
Thanks.
Old Sep 18, 2004 | 05:47 AM
MadRooster's Avatar
Default
No problem!
I came across their sister site which sold standing/parking lights for Audis and Volkswagens.
Ahhh... finally... I'm a "contributer" to the forum.
2004_
Jul 9, 2025 12:39 AM
jgreen
106
Sep 18, 2017 11:46 PM
xfClifford
27
Nov 10, 2015 10:08 PM
KwehCat
Jul 16, 2015 04:48 PM
