Tricky question with easy answer?
Old Apr 28, 2012 | 01:47 PM
FUBU's Avatar
Default Tricky question with easy answer?
Hi all! Hope you are enjoying the weekend!
have a question.. regarding electronics of the N/A coupe rear wing spoiler MOTOR.
If you give it power ( + from battery to + on motor and the same for minus poles) the motor spins one way in this case raises the wing. If you switch the poles, so - on battery goes to + on motor the motor lowers the wing.
So .. how can I make an easy solution with a trigger eg. push down it lowers (- + to + -) and when in middle nothing happens and then when trigger raised the wing should raise (+ - to + -).
What kind of trigger can I use? Could the normal push button for the N/A wing work?
Hopefully some more experienced have a great idea to share
Old Apr 28, 2012 | 05:20 PM
Default Re: Tricky question with easy answer?
SIMPLE Polarity Reversing switch
Old Apr 28, 2012 | 05:24 PM
Another one: Connecting the wires to the disconnect terminals (for power)
google "reverse polarity switch"
Electric window switch would work good.
Old Apr 29, 2012 | 03:42 PM
FUBU's Avatar
thanks bud. that is the one. found one yesterday. I trigger with 2 polarity .. 6 pcs of connections.. thanks for the help anyways James! Have a good one!
rmcdaniel12
Nov 4, 2015 04:08 PM
jimf
Oct 10, 2015 10:22 AM
Sep 26, 2015 10:21 PM
Sep 25, 2015 07:46 AM
lazorouss
Sep 11, 2015 09:16 AM
