Help with logs, how lean does this look?
Old Aug 21, 2012 | 08:58 PM
trevorradman's Avatar
Default Help with logs, how lean does this look?
I appear to be running lean, completely stock. Does this look dangerous? It looks pretty lean as soon as I get on it. Anyone have a healthy stock log I can compare to?
Look at image or rename .txt to .zdl to read through zeitronix reader.
Thanks!
File Type: txt
Old Aug 21, 2012 | 09:02 PM
grip grip's Avatar
Default Re: Help with logs, how lean does this look?
It looks fine to me considering the amout of boost you're running. Now if you were seeing 22psi on the gauge with over 22 degrees of spark, I'd say fatten it to high 11's or low 12's.
On the other hand, I never like to see 13's, but I do when I first floor it and it fattens up around 30mph. If you beat on it everyday, you might want to adjust it for peace of mind, but I doubt you're in any danger.
Old Aug 21, 2012 | 09:33 PM
Thanks Grip. I am just doing pre-mod-logging, I have a pulley and tune ready to go on. I drive this little car very hard.
Is 80% calculated load normal? I'm expecting 100?
Is 98% TPS normal under WOT?
What is your A/F at 10 LBS?
Old Aug 21, 2012 | 09:49 PM
grip grip's Avatar
I only see 98% TPS logging though the ZT2. MY AF is at 10psi for only a split second in first gear (13.5), but it's just a blip as the boost climbs quickly and never drops below 16-17 psi until I let off the gas in 4th gear.
Old Apr 7, 2013 | 04:38 PM
JesseJamessrt6's Avatar
Thanks!
how did you get your graph to have all the values plotted along the curve in your attachment?
Old Apr 7, 2013 | 05:59 PM
32krazy!'s Avatar
zt2 download software. its free and you will read everything asd a graph. tip for the day is dont log so much at once. break the pulls down to a max of 4 to 4 parameters at a time. less data faster refresh rate
Old Apr 7, 2013 | 10:15 PM
These look good right? A little rich but a good thing for a tune in a box. I'm worried about the lower RPM/lower boost lean readings.
Old Apr 7, 2013 | 11:01 PM
The graph above in the previous post was the higest RPM.
This one is of the highest boost (it also maxed out at 19.1 psi just right before full RPM)
This one is the lean spike at initial WOT
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
sk8erjosh09
Sep 4, 2015 09:24 PM
Aug 31, 2015 11:12 PM
