Best Spark Plugs and Wires for modded SRT6
Old Dec 5, 2012 | 02:08 AM
God_Likes_Tebow's Avatar
Default Best Spark Plugs and Wires for modded SRT6
About to put in a 185 crank pulley and also have a dual CAI with a tune, but currently running stock plugs. Whats the best plugs to go with for this setup and the proper gap?
Thanks.
Old Dec 5, 2012 | 08:33 AM
32krazy!'s Avatar
Default Re: Best Spark Plugs and Wires for modded SRT6
for me i used the ngk plugs from rob and magnacor 8mm wires. as for gap i started at oem specs and watched for spark blowout and reduced gap 1mm a ta time until it stopped
Old Dec 5, 2012 | 08:54 AM
grip grip's Avatar
You have too much time on you're hands if you're removing and reinstalling plugs several times to set the gap. It takes me around 90 minutes to swap plugs.
I went with a gap of. 035 when stacked.
Old Dec 5, 2012 | 09:07 AM
32krazy!'s Avatar
i have more than 2 wrenches. it only takes about 30 minutes start to stop
Old Dec 5, 2012 | 09:18 AM
grip grip's Avatar
You must be using magic wrenches then, 'cause swapping plugs in 30 minutes is make believe.
Old Dec 5, 2012 | 09:22 AM
If you reduced the gap at 1mm a time they would be closed after the first adjustment they come set at 1mm gap.
.1 gap reset would be .0354 after one adjustment and this is where they are for 32Kkrazy.
Just to set the record straight, I know the US is unfamiliar with metric sizes etc.
Old Feb 22, 2013 | 12:17 AM
bigblockbill's Avatar
Alright grip grip. I had a great time at test and tune Sunday. I wanted to post my experiences of my first outing of 2013. The car now has an SL55 fuel pump, 185mm crank pulley, a possibly lean flash(no data yet), dual CAI, stacked heat exchangers and a Phantom Grip with 315mm Nittos. With a good launch iIt only ran 8.02 at 86.5 mph. The engine stumbled a little after changing into second and noticeably after shifting into third gear. We discussed the spark plugs so I went to Twilight Zone and got 12 Bosch Iridium IX heat range 7 for $6.99 each. When removing the old plugs I found Bosch Super Plus gapped at .27. I'll be gapping the new plugs at .35. Any idea why they went with a .27? See you at the track.
Old Feb 22, 2013 | 07:43 AM
grip grip's Avatar
Maybe the previous owner was running nitrous. That gap is way overkill otherwise. I think you'll notice a nice power increase opening it up to .035. See you Sunday.
Old Feb 22, 2013 | 10:50 AM
I see it is an old post and I answered before.
Goldwing
21
Apr 2, 2025 11:32 PM
xfClifford
Mar 3, 2021 04:52 PM
rmcdaniel12
Sep 26, 2016 05:37 PM
BrenLW
Aug 5, 2015 04:53 AM
Jul 29, 2015 06:13 PM
