valve cover leak
Old Jan 28, 2013 | 10:43 AM
jediracer's Avatar
Default valve cover leak
There seems to be a leak on the top cover on both sides. I have already ordered the replacement screws needed for the job. Is it recommended to do the lower valve cover ta the same time? Just want to hear viewpoints! Thanks!
James
Old Jan 28, 2013 | 11:04 AM
Default Re: valve cover leak
James
If there is ONLY a leak at the top covers, fix the top covers, leave the valve covers be.
( Go ahead and replace ALL the screws however, and use proper torque )
from dedwards0323 :
During re-assembly of breather cover I checked for valve cover bolt torque setting and found 10 N-m (7-8 Ft-lbs) on the service manual disc I've got. After I tightened the 2 bolts that pass thru the breather cover, I checked the remaining valve cover bolts. Found all of them less than 10 N-m. Re-tightened these bolts also. Then I tightened the 2 small hex head machine screws in the breather cover to 5-6 N-m (slightly over snug).
minimayhem
16
Aug 23, 2016 07:47 AM
maxcichon
Sep 25, 2015 02:55 PM
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
williammt
Sep 6, 2015 11:23 AM
