navi help!
Old Jan 30, 2013 | 08:33 PM
srtsmally's Avatar
Default navi help!
Can you just plug in a OEM navi radio in our cars in place of the standard one and it will work or do you need to add a gps antenna?
Old Jan 30, 2013 | 09:02 PM
bluecoupe's Avatar
Default Re: navi help!
you need a gps antenna, speed sensor wire, will work without reverse sensor wire. also need radio antenna adapter cable
Old Jan 30, 2013 | 09:08 PM
srtsmally's Avatar
Thanks for the quick reply...So I cant just pull out my oem stock radio and plug in the oem navi radio w/out buying all the parts you have listed correct? Are these parts available?
Old Jan 30, 2013 | 10:22 PM
Here is how to install it.
I'll see if I can find the list of additional parts you need.
If you have a 2004 Crossfire you will probably find that all you need to add are the two radio antenna adapter and the antenna, the wiring was already in the 2004's. Plus the radio removal tools.
Here is a picture showing what is required.
Old Jan 30, 2013 | 10:49 PM
srtsmally's Avatar
Thanks for the great info! I have a 2005 SRT6 so I will need all of these items correct? Thanks again!
Old Jan 30, 2013 | 10:55 PM
Mrmiata's Avatar
Are you getting the Nav Discs too? If not.. I'm sure 180 has a link ready to go for you to download from...
By the time most of us find it since they moved all the Technical documents - PDF's , he'll have you fixed up and moved on to the next project...
Old Jan 30, 2013 | 10:57 PM
srtsmally's Avatar
Thanks for your help as well!
Valk
Sep 17, 2015 11:43 AM
Robertwav1
Aug 11, 2015 12:08 PM
waldig
Jul 15, 2015 02:05 PM
SRT-6'er
May 17, 2007 04:20 PM
Sharonaln67
Nov 1, 2006 07:37 PM
