Can an ECU change from car to car?
Old Apr 16, 2013 | 07:50 PM
Fritz123's Avatar
Default Can an ECU change from car to car?
I know the ECU is vin specific to each car. But IF i needed one could I buy a used one from a SLK320 oe xfire of the same year and use it, of course having it some how recoded for the vin in mine???
Fritz
Old Apr 16, 2013 | 10:55 PM
Default Re: Can an ECU change from car to car?
I was told you could have another ECU but it will have to be programmed for the vin. I thought about purchasing a second one for a tune.
Old Apr 16, 2013 | 11:30 PM
I have two for my car one for race and one for mpg,,only the one for race gets almost the same as the one modded for mpg, so now i am setting one up for 100 + octane and the other for 93 octane both will have a tune . jim
Old Apr 16, 2013 | 11:50 PM
Fritz123's Avatar
Thanks guys, I took mine to dodge house today they told me IF I needed an ECU that I couldnt get a used one, that it was vin coded and could only get a new one to replace it.
Now IF i do need one, where can I get it recoded or reprogramed at in the Austin TX area? MB wont do it, the last idiot shop I took it cant do it, Chrysler told me I cant do it. So now where do I stand?
Jeff
Old Apr 16, 2013 | 11:56 PM
Rudy can do it ,,I just told you I have two for my car,,and I had two for the V6 before i put the v8 in it.
Old Apr 17, 2013 | 12:00 AM
Fritz123's Avatar
Yes I know, but Rudy is a long way from Taylor TX. Can he do it at his place and send it to me? Is it that easy?
Old Apr 17, 2013 | 12:18 AM
yes if you have the star system for the crossfire, the Mercedes one will not work on the crossfire. oh! it cost around $10,000.00,,the star system that is
Old Apr 17, 2013 | 10:58 AM
sk8erjosh09's Avatar
Beckmann does it for $250 also by the way. Pick up a used one for $100 and get it unlocked either by Rudy or Beckmann.
Old Apr 17, 2013 | 04:58 PM
Fritz123's Avatar
Thank you Josh, now thats the exact inforormation I was looking for. Direct and to the point.
Thanks
Old Apr 20, 2013 | 06:14 PM
I have a second one I would like to have tuned. How do you contact Rudy?
Old Apr 20, 2013 | 07:04 PM
Send a PM to rcompart
Old Nov 1, 2013 | 10:38 AM
This is a slightly older thread, reviving in case it's needed for future reference.
ECU's can be bought, used and coded to your vehicle. Don't listen to Mercedes!!! But it is a lot more than VIN.
Beckmann can unlock ECU's, and I believe they can code them to your vehicle. Coding is a little bit more expensive I believe, but unlocking is $250.
Rudy, and I can do either as well. Not sure on Rudy's prices, but I can do unlocks for $200, $250 for pre-coded.
All any of us need is the original and the new one. I'm also not sure on turn around time for any of the others but I could get it done the day of, or the next day latest and have it shipped back out.
To expand on the options a little more, unlocking would be used if you have Star and can run "Teach in of Drive Authorization" to program the ECU to the various modules, key data, VIN, Immobilizer etc.. from an ECU in what is considered a "virgin state".
Pre-coded would be a drop in replacement or duplicate.
Old Nov 1, 2013 | 11:28 AM
Is there no way to do it without sending the original ECU? I'm scared to death of it getting lost or damaged and then what?
Old Nov 1, 2013 | 12:16 PM
Unfortunately no, Mercedes made sure that the original has to be torn apart and chips have to be physically removed to extract the data.
The good news is that the boards are extremely durable, electrically and physically. Damaging the files is next to impossible without a ton of heat. Shorts won't even damage the files. Ask me how I know .
reiji
Jul 19, 2015 07:40 PM
WindRestrictor
Jun 16, 2015 12:18 PM
adamlevy
Jun 7, 2015 08:13 PM
Ephr8a
Jun 4, 2015 12:42 PM
cojoman
May 30, 2015 09:43 AM
