options for iphone with factory headunit
Old Apr 16, 2013 | 08:44 PM
Easley15's Avatar
Default options for iphone with factory headunit
i want to play music from my phone but dont necessarily want to change the headunit is there a way to install a aux port? or has anyone found any other way (i know you can play it through the radio but i heard its has static)
Old Apr 17, 2013 | 09:19 AM
rayth's Avatar
Default Re: options for iphone with factory headunit
the playing through the radio tends to be the simplest option, i use
Amazon.com: GOgroove FlexSMART SP ADVANCED Car Mount FM Transmitter and Charger for HTC , Samsung , LG , Motorola and More Smartphones a: MP3 Players & Accessories Amazon.com: GOgroove FlexSMART SP ADVANCED Car Mount FM Transmitter and Charger for HTC , Samsung , LG , Motorola and More Smartphones a: MP3 Players & Accessories
its not the worst one i've heard and gets the job done for the most part until you start driving through a bunch of different radio signals
Old Apr 26, 2013 | 08:47 AM
Jamerian's Avatar
I little invasive but you make a cable with one end being a standard headphone male end and the out and the other 4 wires (2 right 2 left) then wire then to pins 3 - 6 of the back of your factory head... Those are the outputs to the amp. Im 80% sure this will work ..i actually plan on doing this.
Old Apr 26, 2013 | 09:03 AM
I am no electronics expert, but I do know that wiring to the amp inputs with a signal of less than 3-4 volts peak to peak will not give good results. That is why when putting in aftermarket head units, if the pre-amp outputs are listed as 2 volts, you will have to use the speaker wires to drive the amp.
I have tried the following in my Roadster :
Sony CDXGT54UIW_EN_FR_ES - pre-amps are 4v, works fine. ( traded to maxcichon )
Alpine IDA-X001 - pre-amps too low, have to use the speaker wires. ( currently installed )
Blaupuncht Melborne SD27 - plug and play ( still have it )
OEM unit - works fine ( still have it )
Anyone ever measure the p-p of the earphone signal from a smartphone ?
Old Apr 26, 2013 | 09:11 AM
Jamerian's Avatar
Now this i did not know. Thanx for the heads up be fore i wasted my time!
Old Apr 26, 2013 | 12:10 PM
BrianBrave's Avatar
<--- Huge Horsepower
Bipes Automotive iPod / Portable MP3 Adapter
Bipes Automotive Aux Input for Mercedes
SLK Products
Old May 23, 2013 | 06:49 PM
JPT's Avatar
JPT
So has anybody used this with the Stock radio with nav?
syfi
Mar 28, 2026 04:14 PM
blackpepper
Dec 18, 2021 06:17 PM
UNDER PSI
Nov 1, 2015 09:39 PM
livefreeordie
Sep 22, 2015 08:13 PM
Idrenak
Sep 19, 2015 08:17 PM
