Recommended belt
Old Jul 6, 2013 | 10:41 AM
blackpepper's Avatar
Default Recommended belt
My stock serpentine belt broke so I got a 44$ gates belt,two days later it was shredded, I now have a contenical belt and it starting a pattern one rib next to the supercharger is showing wear.I did replace my idler guide pulley but never had a problem til that my idler pulley bearing seized and broke the stock belt so what's the best belt out to use.
Old Jul 6, 2013 | 12:38 PM
RL67037's Avatar
Default
In other threads, they state the Gates part number should be a K081145 for the SRT. Is that the belt you used? If so, and if you are still shredding belts, you might have a pulley alignment problem.
Old Jul 7, 2013 | 07:59 AM
Default Re: Recommended belt
You are correct the idler guide pulley I purchased from napa isnt the correct width,one rib of the belt isnt supported,anyone have the correct part number because the part number I have I got from a search up it here,its the idler guide pulley under the small guide pulley next to the supercharger.
2005 Ragtop
Oct 3, 2015 03:01 PM
4drturbo
Oct 2, 2015 12:58 PM
Sep 26, 2015 10:21 PM
Sep 25, 2015 07:46 AM
RiderJC
Sep 7, 2015 11:19 PM
