false warning lights
Old Jul 11, 2013 | 07:19 PM
kben's Avatar
Default false warning lights
My 2004 Xfire coupe: a couple of weeks ago the low-oil icon turned on,
oil level was OK. the warning light is intermittent.
Last week the low-water icon turned on,
I added a little water and it went off, for a day or two, then back on.
Checked for water leaks, found none, took it to a good shop which also found no leaks.
They replaced the sensor and the burp tank to no effect.
Today the BAS ESP light was added to the list.
My pretty-good shop suggested taking it to a dealer.
Any other advice will be very welcome, including recommended dealer-shop near Seattle.
Old Jul 11, 2013 | 07:30 PM
Default Re: false warning lights
How old is the battery ?
Old Jul 11, 2013 | 07:31 PM
Today the BSN ESP light was added to the list.
Low oil light is probably the sensor in the sump going wonky.
Low water icon also comes on when the coolant is too hot. What does the temperature gauge say? If the gauge is OK then maybe another sensor is wonky as well, but I do not know if there are two temp sensors for the coolant. Maybe the fan controller?
Also check fluid level when the car is cold, it is amazing how high the level gets when the engine is hot.
Old Jul 11, 2013 | 08:07 PM
kben's Avatar
Thanks for the reply,
The battery has been there for enough years to qualify for replacement.
You seem to be implying that could cause warning lights to lite up.
Water icon does not care what the water temp is. it is just on all the time.
The shop that looked at my problems is accustomed to dealing with Mercedes, including the 320 SLK.
But they cannot access what must Chrysler-only programming.
Old Jul 11, 2013 | 08:59 PM
I just know from reading the forum for several years now that when strange things that don't seem to be related start all at once, the battery is often the culprit.
Old Jul 11, 2013 | 10:48 PM
Read these posts.(click)
Kodebuster
Nov 5, 2020 04:06 PM
jgreen
106
Sep 18, 2017 11:46 PM
xfClifford
27
Nov 10, 2015 10:08 PM
KwehCat
Jul 16, 2015 04:48 PM
westonrose
Jul 14, 2015 11:25 PM
