Help with installing new bulbs
Old Sep 30, 2004 | 07:34 PM
roms33's Avatar
Default Help with installing new bulbs
I still have not been able to remove the dam stock bulbs. If any body can give me some advice on it would be greatly apreciated.
Old Sep 30, 2004 | 08:42 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Help with installing new bulbs
are you referring to the headlamp, fog lamp or turn signal bulbs?
Old Oct 1, 2004 | 12:19 AM
roms33's Avatar
Default
andrew there for the low beams
Old Oct 1, 2004 | 02:19 AM
MadRooster's Avatar
Default
First take off the wiring harness connected to the bulb. Remember how you took it off so you can put it back on the same way. Then there is a retainer clip shaped like a "v". At the point of that "v", there is a hook holding it in place. Free the retainer clip from the hook and the bulb will come out. The bulb can sit in the hole in one specific orientation. Put the new bulb in. Replace clip. Replace wiring harness. Pau ("finished" in Hawaiian).
Old Oct 4, 2004 | 12:39 PM
roms33's Avatar
Default
MadRooster , thanks for the help man!I got the bulbs in and there pure white and a little britter than stock.
55chevy
Jul 22, 2024 02:31 PM
UNDER PSI
Nov 1, 2015 09:39 PM
ritous1
Sep 26, 2015 01:27 PM
bbsrt6
Sep 19, 2015 11:21 AM
maxcichon
Sep 4, 2015 12:50 PM
