AC Blower
Old Aug 30, 2013 | 01:33 PM
bruce001's Avatar
Default AC Blower
I just got back to Florida where my Crossfire has been resting for about two months. The AC fan does not work. I suspect it is the blower motor or the switch. Any ideas how to diagnose? The red light on the AC button comes on but no air moves . BTW it's hot down here.
Where would I locate the fuse for same?
2005 Roadster Ltd.
Old Aug 30, 2013 | 02:24 PM
rmaier's Avatar
Default Re: AC Blower
Inspect Fuse 15 located in the Underhood Accessory Fuse
Block. If the fuse is open, repair the cause of the open fuse before
continuing.
Old Aug 30, 2013 | 03:04 PM
bruce001's Avatar
continuing.
Is that the box next to the battery? The fuses do not appear to be numbered.
Old Aug 30, 2013 | 08:06 PM
maybe you should check this , it is common for to go bad I replaced mine about six months ago,
there is a how-to somewhere in search I could not find it. It's pretty easy. It's up and behind the glove box, is held in with two screws, by the way the wire they supply you is too short to keep your factory wire jim
http://www.google.com/aclk?sa=l&ai=C...2B2003&cad=rja
Old Aug 31, 2013 | 09:07 AM
No, it's next to the brake cylinder in front of the driver, right next to the fender.
Valk
Jul 12, 2021 09:49 PM
55chevy
Sep 13, 2015 07:38 PM
rdougc
Sep 5, 2015 10:30 PM
x1xsinisterx1x
Aug 24, 2015 07:31 PM
mthtulsa
Aug 3, 2015 06:14 PM
