Door locks/hatch lock/lights/gas tank
Old Sep 12, 2013 | 10:17 AM
Chelle007's Avatar
Wink Door locks/hatch lock/lights/gas tank
I thought i'd share this with everyone. I recently started having an issue with my Crossfire:
1) Doors only locking/unlocking when they wanted to.
2) Hatch only locking/unlocking when it wanted to.
3) Key fob would make the lights flash (like it is suppossed to) but wouldnt lock or unlock anything.
4) Gas tank lid wouldn't pop up for me to put gas in.
5) Lights- sometimes when the car was turned off, one light would come on and not go off causing
the battery to drain if it happened in the middle of the night). Sometimes the lights would flicker.
6) Random dash lights would come on: Check Engin/Tire Pressure/some i still dont know what they mean
All of these problems were due to the "central locking vacuum pump" not working. Apparently my back tail light had a leak. When it would rain, the water would drip down onto the flooring of the trunk/hatch. This part happens to be located underneath the flooring. Once this was replaced- EVERYTHING started working perfect.
They had to replace this pump and have it programed to my car. I'm told you can't get this part off of another car because once it is programed to a car, it can't be reprogramed to another.
Here is the part #
Mercedes part- #17080000848 (it cost me $575.95 plus $125.00 to have it programed to my car).
I hope this helps someone out because it took me a few months of research to figure out what my problem was.
Old Sep 21, 2013 | 12:47 PM
Default Re: Door locks/hatch lock/lights/gas tank
I think they hosed you, that module doesn't need 'reprogramming' to your car. Many here got that central locking module second hand, and just installed it. Another example of the 'Stealership' working its 'Magic'...
Old Sep 21, 2013 | 01:06 PM
It is amazing what goes on at stealerships.That module is plug and play. I'd go back and ask them why they charged you that fee. If that is written down you should have them by the short and curlies.
If you had asked here first we could have saved you some money, too late now but in future check here first.
Old Sep 21, 2013 | 06:49 PM
SNAKEWOLF's Avatar
If there is a slow leak in the system it will cause some of the above listings to happen. Repair the leak and they will disappear. In a pneumatic system I always check for leaks first then electrical problems. The manual checks wiring then switches then pneumatic hoses. I just have found doing in reverse saves time.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
paine2907
Oct 2, 2015 10:01 AM
Billy22Bob
Sep 28, 2015 08:08 PM
jaesa
Sep 7, 2015 01:50 PM
