Wind noise from drivers window
Old Sep 30, 2013 | 10:13 PM
Penniman's Avatar
Default Wind noise from drivers window
Hey guys I've fixed almost all my problems with my crossfire other then this wind noise. I've adjusted the window multiple times to no help I have it fully tilted inwards. I completely removed the door sill and reseated it. I tried wedging probably a rubber tube between 1/2 to 3/4 inch like some members recommend on other posts and I still can't get rid of the noise. And it's not just at highway speeds either. It starts up at about 30 to 35 mph and just gets worse as you increase in speed. Any other ideas? I don't think there's anything wrong with the seal no rips or tears from what I could see. It sounds like it coming from around the mirror area maybe even a little farther up like where the door seal starts.
Old Sep 30, 2013 | 10:42 PM
SNAKEWOLF's Avatar
Default Re: Wind noise from drivers window
Review Section 23-88 Door adjustment in free downloadable service manual. Hope this might help.
Old Sep 30, 2013 | 10:50 PM
Penniman's Avatar
Default
Is this the section that tells you how to remove door panels and adjust windows up down and front to back and also how to tilt in and out? Because if so I have done that at least 3 to 4 times.
Also guys I've read that the roadsters trim around the windshield and cause wind noise is this the same cause as the coupes? If so wouldn't I also hear it when I had my windows down?
Old Oct 1, 2013 | 01:37 PM
SNAKEWOLF's Avatar
no this is how to adjust the door itself. My door was a little far to the outside leaving the gap open on the inside had to adjust door hinges.
Old Oct 1, 2013 | 03:22 PM
Penniman's Avatar
Default
Thanks I'll try that sometime this week or weekend do you have a link to the service manual ?
Old Oct 1, 2013 | 03:56 PM
SNAKEWOLF's Avatar
https://www.crossfireforum.org/forum...tos-forum.html
Look in above link
usprb1976
Apr 4, 2024 04:57 PM
xfireohio
Jul 20, 2020 12:03 AM
RedNeck
Sep 4, 2015 09:54 PM
Gtsman
Sep 3, 2015 08:48 PM
Xfirenewbie
U.K.
Aug 13, 2015 04:39 PM
