Steering box adjustment?
Old Nov 1, 2013 | 11:24 PM
MB Star's Avatar
Default Steering box adjustment?
Is there any adjustment in the steering box? Some steering boxes have a screw with a lock nut that allows you to take up any play in the gears, is there anything like that sort of adjustment?
Old Nov 2, 2013 | 12:18 AM
arejohn's Avatar
Default Re: Steering box adjustment?
Yes there is. Never saw a post from anyone adjusting it though. Looseness in steering typically attributed to stabilizer.
How many miles that you are asking?
Old Nov 2, 2013 | 09:12 PM
MB Star's Avatar
84k on the car
Old Sep 22, 2017 | 05:12 PM
twodoe's Avatar
I would like to adjust mine also. I am thinking of cutting a hole in the heat shield to get to the adjustment screw/nut. I would need to repair that after. Hadn't thought it all the way thru yet.
Old Sep 22, 2017 | 06:26 PM
Manual doesn't show picture of the adjustment screw and nut :
Old Sep 22, 2017 | 06:30 PM
Steve Jr's Avatar
Have you replaced the steering stabilizer (dampener) yet? There is a noticeable in difference in response, when you do. Especially if its higher mileage car.
Old Sep 22, 2017 | 08:00 PM
twodoe's Avatar
Yep it's new. And I made sure the pinch clamps are tight. I am going to put on new shocks. The looseness in the steering is more pronounced when off center. I have adjusted steering gears before to fix the problem in other cars. This one is just so hard to get to.
Old Sep 22, 2017 | 08:06 PM
twodoe's Avatar
The adjusting screw and jam nut are on top the box just under the heat shield. I may try and fashion a wrench that can loosen the jam nut from below and make a small hole in the heat shield got the hex wrench. That is if all the planet's align and Orion decides walk across the sky.
Old Dec 23, 2019 | 08:12 PM
nelro_PL's Avatar
hi, did You do this adjustment in Your car?
I tried to take off the exhaust but 2 bolts couldn't even reach with the key. So is there any other way to make this adjustment?
Thanks in advance for replay.
2005 Ragtop
Oct 3, 2015 03:01 PM
Mackel
Sep 29, 2015 02:41 PM
toob
Sep 26, 2015 11:44 AM
cdcrone123
Sep 20, 2015 10:02 PM
bbsrt6
Sep 19, 2015 11:21 AM
