[2004 3.2 M112] Cylinder numeration
Old Dec 11, 2013 | 04:25 AM
Kali_PL's Avatar
Default [2004 3.2 M112] Cylinder numeration
Dear All,
I'm a little bi confued while searching the internet.
I need to repleace three iginition coils on cylinders 1,2 and 3, but i have no idea which ones are those.
Can You help me with identification on cylinder numbering ?
Thanks in advance
Lukasz from Poland
Edit:
Or maybe there is another problem, i have such code errors:
P0134
P0154
P0300
P0301
P0302
P0303
Any help ?
Old Dec 11, 2013 | 07:09 AM
Default Re: [2004 3.2 M112] Cylinder numeration
Here ya go :
Old Dec 11, 2013 | 07:12 AM
Kali_PL's Avatar
Here ya go :
Thank You very much that will hepl me.
Do Yu think that it is possible that 3 coils on one side of engine could fail ?
or maybe it is problem with Camshaft Sensor ?
Best Regards
Łukasz
Old Dec 11, 2013 | 07:17 AM
Unlikely that 3 coil packs fail at once.
1. Crankshaft sensor.
2. Camshaft sensor.
3. PTCM ( PCM )
Fuse 11 supplies power to all 6 coil packs, see diagram
Old Dec 11, 2013 | 07:24 AM
Kali_PL's Avatar
2. Camshaft sensor.
3. PTCM ( PCM )
So i guess there was no need for me to buy 3 ignition coils :/
there is one more info:
engine cuts off those cylinders only when ts hot, on cold everything seams to be fine.
Shall i change those coils or shall i buy and replace both sensors first ?
Best Regards
Luaksz
Edit: Camshaft/Crankshaft sensor failure should give any error i guess ?
Old Dec 11, 2013 | 07:38 AM
S. Artee's Avatar
Have you checked the spark plugs on the cylinders in question?
Also, if you have access to a borescope, I would have a peak inside while the plugs are out.
Does the car smoke at all?
Sounding more and more like an intermittent wiring fault.
You can eliminate the defective coil question by swapping all 3 coil packs from 1,2,3 to 4,5,6.
Often, crankshaft / camshaft sensor being defective does not store any error codes.
Old Dec 11, 2013 | 07:41 AM
Kali_PL's Avatar
Those were changed about 6-7 months ago, i bought high quality so i don't think that something is wrong with them, especially as the issue is on whole left side of engine (
Best Regards
Łukasz
Old Dec 11, 2013 | 07:52 AM
Kali_PL's Avatar
Ok, I will replace those 3 coils with new ones - less work and let You know if it helped.
I will also read the error codes after replacement and post them here
Thanks a lot for all information's.
Best regards
Łukasz
Old Dec 11, 2013 | 07:53 AM
Kali_PL's Avatar
Car is able to ride, there is no blue or black smoke, I do not have the access to borescope.
Thanks
Łukasz
Old Dec 11, 2013 | 10:01 AM
sk8erjosh09's Avatar
I know someone that just had this problem and his 02 sensor for that bank went out.
Old Dec 11, 2013 | 10:04 AM
Good catch Josh !
Old Dec 11, 2013 | 10:13 AM
Yeah it had me and him scratching our heads to the point of skinning our brains. lol
What are the other codes: P0134, and P0154?
Old Dec 11, 2013 | 10:14 AM
Kali_PL's Avatar
Good catch Josh !
So it can be caused by O2 sensor ?
My errors:
P0134 - Oxygen 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 One Misfire Detected
P0302 Cylinder 2 Two Misfire Detected
P0303 Cylinder 3 Three Misfire Detected
Old Dec 11, 2013 | 10:17 AM
Description of vehicle trouble code P0134 - Oxygen 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
So we have O2 sensor codes on BOTH banks ?
Could it be setting these at startup with a faulty air injection pump / circuit ?
Old Dec 11, 2013 | 10:19 AM
Kali_PL's Avatar
Both 02 errors occurred over an year ago (my mother is a car user and she just told me that :/ )
Old Dec 11, 2013 | 10:31 AM
Yes, very much so. The O2 is very important for A/F.
I think it would throw the P0410. It may have been a slightly bad O2 on bank 2 but a completely shot one on bank 1 for every cylinder to missfire.
Was anything done because of them?
Old Dec 11, 2013 | 10:32 AM
One thing to try is to take where the O2 sensors plug into the black connectors and switch them. See if you missfire on 4, 5, and 6.
EDIT: Or missfire on all cylinders, because at that point the ECU is determining A/F for the wrong banks.
Old Dec 11, 2013 | 10:43 AM
Kali_PL's Avatar
I'm not sure where shall I seek for o2 sensors
Old Dec 11, 2013 | 10:56 AM
They go into the exhaust manifolds. Near the rear of the engine bay. The black plugs are right on the firewall I think (not sure, because mine are different).
