top will not close
Old Jan 14, 2014 | 02:07 PM
richardreyn78818's Avatar
Default top will not close
hi guys, my top will not close all the way. i have a draw so i removed the ground cable to do a
draw check. it was the dio-soket when i pulled the fuse the draw stopped. now my top gose down good but will only go up to 6" from closed. help. rich.
Old Jan 14, 2014 | 02:16 PM
Default Re: top will not close
What is a dio-socket?
If your top is really not going up all the way, it's either low fluid, bad pump or bad limit switch on one of the cylinders.
Can you either make and post a quick video or take a picture of it in the farthest-up position and post it here?
Old Jan 14, 2014 | 02:27 PM
thanks, but i just had the top redone. could it be reset
Old Jan 14, 2014 | 02:32 PM
What do you mean you had the top "redone".
You first posted that tracking down the 'drain' caused this, now you have changed the story to "I had the top redone".
If someone replaced the top and messed it up, take it back to them!
Old Jan 14, 2014 | 02:38 PM
Here is a thought: Can you put it up manually?
THAT will tell you if it is improperly installed or if it is electrical/hydraulic in nature.
Old Jan 14, 2014 | 02:46 PM
Manual top operation:
Old Jan 14, 2014 | 06:19 PM
Nice video Mark...
Old Jan 14, 2014 | 07:04 PM
FIXRE's Avatar
What a contribution! I am going to practice this week-end. Thanks for all you do Mark.
Old Jan 14, 2014 | 08:46 PM
You are all welcome, and thanks.
Now, I wonder what's going on with the guy and his top... Sounds like another "excellent" dealer experience....
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Sep 25, 2015 02:16 AM
