Heat stays on
Old Feb 19, 2014 | 06:10 PM
Griselda Palmer's Avatar
Default Heat stays on
With a/c on it still blows super hot! I see the compressor is coming on but stays blowing hot! The other day it worked briefly...the system is not cycling either.
Old Feb 19, 2014 | 06:11 PM
Default Re: Heat stays on
What I mean by cycling is the compressor stays turning..not off and on like its out of freon
Old Feb 19, 2014 | 06:17 PM
Are you SURE the A/C is not working? These cars have a tendency to deveop a problem with the valves that control heater water. Mine will "stick" and give me 100% full on heat on the driver's side once in a while. The only way to stop it, is to shut the car off, then restart it - fixed. (Acts up when I turn the heat **** up fully, then when I turn it down, the valve seems to stick).
So, is the A/C really not working, or is the heat staying on?
If the heat is not staying on, and you can tell the pump is engaging, then either the condenser up ahead of the radiator is FULL of leaves, the fan isn't running (if it cools as you speed up, that would indicate the fan under the hood is not running when it should, but this would also imply overheating of the engine at times would also happen) or the system has leaked out.
Old Feb 19, 2014 | 06:25 PM
The compressor clutch is engaging and stays running so I'm good there..it's got to be a sticking valve problem
Old Feb 19, 2014 | 06:38 PM
Hey Mark, any idea what happens if you simply unplug the connector to the heater valves ?
It is a pulse width signal to them, I would assume they would shut, but now that I think about it, since these are German cars, maybe they go full open ?
Old Feb 19, 2014 | 10:04 PM
Well Mark....?? I'm anxious to hear this
Old Feb 19, 2014 | 10:05 PM
Where is this switch located?
Old Feb 19, 2014 | 10:33 PM
Padgett's Avatar
Sounds more like a blend door issue. "In a blend-air system, a blend door controls the amount of unconditioned air (or cooled air from the evaporator) that is allowed to flow through and around, the heater core. A temperature control on the A/C heater control panel determines the discharge air temperature by energizing the blend door actuator, which operates the blend door. This allows an almost immediate control of the output air temperature of the system."
Old Aug 3, 2024 | 05:24 PM
Tony Cooper's Avatar
I agree it very much sounds like the blend door. However I have a question regarding the location of the blend door actuator in the crossfire ? Can anyone answer the question without guiding me to a workshop manual ? Cheers
Old Aug 3, 2024 | 05:38 PM
Old Aug 5, 2024 | 01:15 PM
xintersecty's Avatar
The hot water valves are described here plus a possible fix for your issue:
https://www.crossfireforum.org/forum...lected-ac.html
Old Aug 6, 2024 | 11:22 AM
dcskmail's Avatar
Look up duo valve clean/repair and any other problems you may have with your Crossfire on Youtube, sometimes Merecedes SLK 320 will come up but it's the same, this site will not let me post the link
cincinattirick
Feb 27, 2020 12:38 PM
darknightdug
Jun 20, 2018 06:38 PM
JCostakis25
Apr 23, 2016 08:18 AM
ElenaB
Jan 30, 2014 03:18 PM
ejc45carter
Apr 1, 2005 10:11 PM
