Question Regarding Skicky Key Fix
Old Feb 19, 2014 | 06:53 PM
Reichsrundfunk's Avatar
Default Question Regarding Skicky Key Fix
A few weeks back I had my sticky ignition key repaired by my Indy. It has completely frozen, so he had to drill out the locking pin to get the assembly out. Once out, he opened the little trap door cover and removed the spring and the pin which extends out to the steering column.
All is well and the assembly has been working like butter ever since. Only thing is that when you turn off the ignition and remove the key, the steering wheel still locks! My understanding is that with that pin and spring removed it should no longer be possible to lock the steering wheel. Is that correct or am I misunderstanding something very basic about this assembly? Not that I'm complaining, but the curiosity is burning a hole in my brain!
Old Feb 19, 2014 | 06:54 PM
Default Re: Question Regarding Skicky Key Fix
the steering wheel should still lock after doing the sticky key fix.
Old Feb 19, 2014 | 06:55 PM
whoosh's Avatar
I could be wrong, but I think it still locks. I have not done mine yet..any day now.
Old Feb 19, 2014 | 07:13 PM
Of course it still locks, what you removed (so I have been told) is a redundant latch that keeps the plunger extended unless you turn the key.
With the parts gone, there is no "LOCKING" of the plunger, but that does not matter, since there is no way to get in there and push the plunger back anyway. And THAT is apparently why MB left those two parts out in 07 and 08 models.
Old Feb 19, 2014 | 07:19 PM
OK, well I guess thats over-engineering at it's most exquisite. So, what extends the plunger in that locks the wheel anyway??????
Old Feb 20, 2014 | 07:17 AM
pjm30144's Avatar
Pizza is the man!! He is totally correct as usual!
Old Feb 20, 2014 | 07:19 AM
pjm30144's Avatar
When you turn the key that moves a slide in the ignition housing that has the steering lock tab on the end
KDW4Him
18
Sep 1, 2021 05:47 PM
jhansen
21
Feb 15, 2017 04:26 PM
gtjl
17
Jul 22, 2015 06:28 PM
Bayukbros
Jul 17, 2015 04:22 PM
Fildo Dog
Jul 6, 2015 05:20 PM
