Transmission cooler lines hooked to lower radiator area?
Old Apr 1, 2014 | 06:25 PM
RED DOG's Avatar
Default Transmission cooler lines hooked to lower radiator area?
I have to admit I'm a bit more experienced working from above the car than from underneath it. I've spent a couple hours searching the forum and can't seem to find what I need to know. I need some advice / confirmation on where the transmission cooling lines connect to the radiator. I THINK I see two lines . . . one connected to each side of the lower radiator area. I presume one is the incoming transmission fluid and one is the outgoing transmission fluid. Which side of the car is the incoming fluid line? Does anyone have a picture so I can confirm that I'm actually looking at the correct transmission fluid lines hooking up into and out of the radiator? Thanks in advance for sharing your expertise . . .
Old Apr 1, 2014 | 07:30 PM
Default Re: Transmission cooler lines hooked to lower radiator area?
Both inlet and outlet cooling lines enter the rad on the lower passenger side. One of the lines come up the frame on the drivers side, then crosses under the fan. The driver side is for the AC condenser. I have no idea which is inlet and outlet.
Old Apr 1, 2014 | 07:44 PM
RED DOG's Avatar
OK that's some progress. I see the two lines you described.
Old Apr 1, 2014 | 08:57 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
'05 SSB SRT6 Roadster Build #52890
'05 Black SRT6 Roadster Build #54435- "Rescue Roadster Restoration Project"
'05 SSB SRT6 Coupe Build #39549 - "Damsel in Distress Project"
Bob....three SRT6's in your sig. When did you pick up the third?? How did I miss that?
Old Apr 1, 2014 | 09:13 PM
RED DOG's Avatar
I flew up to Orlando, bought it (read as stole it) and drove it home last Sunday . . .
Old Apr 2, 2014 | 08:08 AM
ImportLabSRT's Avatar
Drivers side line is out (from the trans) and passenger side is in (to the trans).
Old Apr 2, 2014 | 01:37 PM
RED DOG's Avatar
P E R F E C T ! THANKS, Time to get the tools back out . . .
Old Apr 2, 2014 | 01:40 PM
Bob, you are gonna need a bigger trailer to get all those to the Dragon ........
( Time for a used NASCAR car hauler )
Old Apr 3, 2014 | 06:10 AM
You're welcome, glad I could help. If you have a leaking line, I have my stock lines in my stock parts bin. They only have 24k miles on them if you need them.
waldig
Sep 2, 2015 11:02 AM
Jul 29, 2015 06:13 PM
waldig
Jul 29, 2015 06:54 AM
Jerrysrt6
Jul 24, 2015 09:15 PM
waldig
Jul 20, 2015 08:10 AM
