Exhaust tips
Old Jun 25, 2014 | 11:15 AM
xme's Avatar
xme
Default Exhaust tips
Ok, I know there are tons of threads on how to clean the exhaust tips... But I figured this was the best place to post this:
My exhaust tips were BLACK on the inside. Heavy coats of carbon. Went out and got some Meguiar's Hot Rims and never dull, and started going to town and found this:
At first I thought it was just discoloration, but as I cleaned m ore I discovered the inside of the exhaust tips were painted Aero Blue (previous owner I assume). In any case, they didn't use high temp paint and it's baked on pretty good, and badly discolored.
Now it looks way worse than it did when I started. Any suggestions on getting the remainder of the paint off without damaging the tips? I was thinking aircraft remover? The bare metal looks like it's fine underneath the paint...
Thanks!
Brian
Old Jun 25, 2014 | 12:45 PM
Bill F's Avatar
Default Re: Exhaust tips
Thanks!
Brian
See if paint remover will do it. If not you can always paint the inside black with high temp like many of us did.
Old Jun 25, 2014 | 01:59 PM
ewaynec's Avatar
I put this on another post, but I don't remember where.
Mine were brown, like a burned metal, I tried several things with no results. My wife suggested the stuff she uses to clean the glass stove top. I did and it worked great. I used a toothbrush to make sure I got into the crevices, then washed it off. They shine like new metal now, and I'll bet they can clean yours too.
Old Jun 25, 2014 | 02:28 PM
xme's Avatar
xme
Thanks for the, er, tips guys. Pun totally not intended It's soaking in some paint stripper now, and I actually have some of the glass top range cleaner kicking around. Wish me luck!
Old Jun 25, 2014 | 02:33 PM
Speedy4x4's Avatar
Was it "simple green"
Old Jun 25, 2014 | 03:49 PM
Use a very light polishing pad on a dremel and some metal polish and it will be history and they will be polished in one step
I have the tips, polish, dremel and garage if your method does not pan out...
Old Jun 25, 2014 | 04:14 PM
xme's Avatar
xme
That would be really great if it isn't too much trouble John... I got the worst of it, but it still needs some work:
Old Jun 25, 2014 | 05:07 PM
STEPHENJXN's Avatar
I will call this thread closed...GOOD JOB!!
Old Jun 25, 2014 | 06:39 PM
SRTs come painted black from the factory. Funny thing is some owners do not realize this and try to clean them. Oops!
Old Jun 25, 2014 | 10:56 PM
Nice job!!!
Yeah, I've liked my OEM SRT tips painted black. They look good and are less maintenance
Old Jun 26, 2014 | 06:55 AM
Although you did a good job on them, why would you want to see a black round hole in a shinny square type opening. I like them black myself.
James
Old Jun 26, 2014 | 07:00 AM
I like mine painted gun metal gray :
Old Jun 26, 2014 | 07:52 AM
xme's Avatar
xme
I couldn't even paint them in good conscience the way they were. I'm not sure the picture really does any justice of how bad they were. There was years of carbon, then a (bad) paint job, and then years of carbon again so there was a visible texture. It would have looked like I slathered the inside of the tips with concrete, and then painted it :-p
I was pretty surprised to find it though. Everything else on the car is in very good shape.
Old Jun 26, 2014 | 09:14 AM
Yeah, no problem, you may need to stop at lowes on the way and grab a few of the very light steel wool type polishing pads for the dremel, I will check if mine have any life left. I know your work schedule is crazy, just shoot me a text...
Old Jun 27, 2014 | 10:40 PM
JEFASOLD's Avatar
You got me on that one, I was one of the dummies that cleaned them. LOL However, I will remedy that soon.
Old Jul 10, 2014 | 12:42 PM
xme's Avatar
xme
Well, while I was down in TN... I went ahead and hit it with some commercial appliance cleaner. Pretty aggressive stuff made for cleaning cooktops and deep fryers and such. There wasn't anything left after that! With the tips finally clean, I went ahead and painted it black with some high temp paint. That should be much lower maintenance. LZGUrni.jpg
Old Jul 11, 2014 | 08:01 AM
Looks nice and clean!
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
cuziamninja
Oct 5, 2015 10:39 AM
Sep 28, 2015 07:40 PM
gblack32
Sep 26, 2015 10:00 PM
