Code PO600 What is were is the Serial Communication link malfunction?
Old Jul 23, 2014 | 08:18 PM
yorktown4's Avatar
Default Code PO600 What is were is the Serial Communication link malfunction?
UPDATE
PULLED THE RCM OUT AND RE-SOLDIERED PER TIGHED1 ADVISE. Car restarted. Let car run for 5 minutes. Came back and had warning lights on low tire pressure, brake wear indicator light, ABS, BAS esp, brake, and seat belt.
Turned off engine to read the codes. Code came back on as PO 600. Car will not restart.
Anyone know what to try next?
I got a code PO 600. Car will not start and the rear spoiler is up. Checking the battery I found it weak. After replacing the battery the engine still wouldn't turn over. I checked the codes again and there was no codes showing after replacing the battery. Were can I check to find the problem and were is it located.
Old Jul 23, 2014 | 08:25 PM
Default Re: Code PO600 What is were is the Serial Communication link malfunction?
If the rear spoiler is up, then I'd start with a new battery.
Old Jul 23, 2014 | 09:30 PM
yorktown4's Avatar
The battery in new
Old Jul 24, 2014 | 07:54 AM
tighed1's Avatar
Wing up could be a battery or connection problem.
If it won't crank (turn the starter over) check the RCM link in my signature.
PO600 checks can be found in the manual.
Check in the Service Manual (HERE).
Download the "2004 Crossfire Coupe Only" version and start at page 9-425.
Old Jul 24, 2014 | 09:26 AM
ABS unit may be faulty.
Read these posts.
Old Jul 26, 2014 | 05:29 PM
yorktown4's Avatar
I can't understand why after car sits for a day, it starts right up. After is runs for 20 minutes the warning lights come back on
Old Apr 28, 2015 | 08:39 AM
Cubanfisher's Avatar
ever figure it out? i have the exact symptoms and order a abs module from ebay for it. thanks ill find out this week if it fixed it.
TOPLESS
Feb 9, 2016 11:28 AM
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
tritongreen
Sep 18, 2015 07:32 AM
MickeyNasty
Sep 6, 2015 08:29 PM
