battery
Old Dec 10, 2014 | 07:31 PM
gerry44's Avatar
Default battery
My battery needs to be cleaned. As with most cars if you unhook the battery you have to have someone reset the computer is this true on the crossfire or can you unhook, hook the battery back and go!
Old Dec 10, 2014 | 07:43 PM
Default Re: battery
No problem.
You might loose the radio presets.
Old Dec 10, 2014 | 11:29 PM
JEFASOLD's Avatar
Default Re: battery
No problem.
Nope, not even the presets, you will be good to go.
Old Dec 21, 2014 | 12:15 PM
fdhrusty's Avatar
Default Re: battery
Advance Auto will copy your computer date onto a flash drive, replace your batter and then reload the copied data back onto the crossfire computer.
Old Dec 21, 2014 | 12:17 PM
fdhrusty's Avatar
Default Re: battery
I have a 2006 crossfire and if it sits in my garage for 1 week, the battery will need to be recharged. There is a new battery in my crossfire and is this typical?
Old Dec 21, 2014 | 01:04 PM
Default Re: battery
well, it should hold up longer than a week. cranking amps is usually what suffers. if it is rated at a lower number of cranking amps, in other words a less expensive battery, that may be your problem. Cold temps will cause this as well... Have the battery "load" tested and see what the results are.
Old Dec 21, 2014 | 04:23 PM
gerry44's Avatar
Default Re: battery
You say it's a new battery? Maybe not. I have a 2014 Dodge Ram just a year old and on my second battery. It all depends how long that battery sat before you bought it in my case with a new truck the battery should have lasted for a least 5 years in this desert. Either that or you have something draining on the battery while it's sitting. Try disconnecting the battery while sitting then hook it back up it's the battery if the conditions stay the same
blackpepper
Oct 4, 2017 06:09 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
