Found a Shop in LA area
Old Jan 14, 2005 | 11:42 AM
Dan Root's Avatar
Banned
Thumbs up Found a Shop in LA area
Finally find a shop (EUROREV) in LA that knows what they're doing with ECUs springs wheels at a great price.
I had them do a Eibach pro kit and ECU.Yesterday" smiles."
Babeviper did his also .
Interesting thing about my car VS his that my car was 1 inch lower already !
It seems that DC sent early cars out with taller springs.
My wheel gap now stands at about 1 inch in front & about 1&1/4 in rear.
Old Jan 14, 2005 | 03:21 PM
english_bob's Avatar
Default Re: Found a Shop in LA area
Dan,
Do you know the VIN range when DC fitted the taller springs?
You may have solved that thread we had in Sept/Oct where everyone couldn't agree on the height from the wheel or the rim to the body. We wouldn't have been able to agree if we had different height springs fitted as standard!!
Looks you have a great shop on your doorstep.
Old Jan 14, 2005 | 03:37 PM
NJspeed69's Avatar
Whaaaat.. the earlier cars have taller springs? That sucks.
Old Jan 14, 2005 | 09:03 PM
CyberGreg's Avatar
Dan - Do you have contact information, web site, email, phone?
Thanks
Old Jan 14, 2005 | 09:17 PM
Dan Root's Avatar
Banned
Babeviper vin# was 0450+ -very early.and his was 1 inch more stock!
Eurorev #866-7000-REV,,,Tim or Jesse
Old Jan 16, 2005 | 09:08 PM
drhrsh's Avatar
Hey Dan,
Sounds awesome. What part of the VIN are you referring to? After the "X" on my VIN, it reads 002889. I bought the car in Aug '03. I was curious and measured my gap between top of tire and lower edge of fender as 1 3/4 " front and 2 5/8 " rear. That's a lot taller than you!!! Are these springs able to be installed by a home mechanic?
How did the ECU mod work out? I didn't see you mention anything about it?
Old Jan 16, 2005 | 09:15 PM
Dan Root's Avatar
Banned
The ECU gave it more pull 2000rpm thru.to red line,feels much smoother and no flat spot.The springs I'd reccomend not at home.Are you in LA area ?
Old Jan 16, 2005 | 09:17 PM
Dan Root's Avatar
Banned
Today,can you tell from yours ?
Old Jan 16, 2005 | 09:34 PM
drhrsh's Avatar
Dan,
Thanks for the pic...quite a difference from mine!! I really like the look. Did it affect your ride? I'm in the Denver area. We do have some pretty serious tools, and my son is an ASE certified Tech.
Old Jan 16, 2005 | 10:18 PM
Dan Root's Avatar
Banned
It actually rides the same only better !
1.it has less bounce
2.less roll
3.quicker or firmer rebound feel
if you have the tools and a lift go for it .
Old Jan 18, 2005 | 12:06 AM
HDDP's Avatar
Dan:
Do me a favor. Take your car to a parking lot and back it up, turning the wheel all the way over to the lock either way and let me know if your tires rub (grind)
Old Jan 18, 2005 | 09:31 PM
EUROREV's Avatar
There is no grind we checked that when it was at my shop
Old Jan 19, 2005 | 10:21 AM
babeviper's Avatar
yes guys this shop is the real deal! if you check my signiture comments you will see that i have been using this ecu-program from eurorev for 8-month with out a problem,and its not only that , its their professional approach and kit glove way of handling the customer and the car is what made me share this shop with dan root, i will be posting pictures of their personal cars and of their shop,if you like what you see with my car, then you really should check them out!
Old Jan 19, 2005 | 10:45 AM
mhorn's Avatar
Do they have a webpage or some other way of getting more information?
Old Jan 19, 2005 | 11:16 AM
Dan Root's Avatar
Banned
you can try www.eurorev.com
Kodebuster
Nov 5, 2020 04:06 PM
michaelcycle58
Jul 28, 2015 08:12 PM
UNDER PSI
Jul 18, 2015 02:12 PM
Jul 16, 2015 08:35 PM
bradleykologek
Jul 6, 2015 02:49 PM
