Double wrench service confusion...
Old May 16, 2015 | 04:36 PM
minimayhem's Avatar
Default Double wrench service confusion...
Today I changed the oil on my Xfire. Its on 64K and is an 06 model. I have no service history, but the FSS was indicating it was oil chance time.
So for good measure, I replaced the oil, oil filter, air filters and auxillary belt and coolant. Im going to do the fuel filter in two weeks. I greased everything hinge wise and am going to go through all visible bolts, remove, clean with a wire brush and refit with grease. I've already done most under-car bolts. I'm also going to get the car on a lift and put anti-rust coating on the underside.
I reset the FSS today and it now says 10,000 miles a double wrench is due. But I thought double wrench was due at 60,000?
Although I have no service history I know the front discs and pads are new, the rears are looking very good (disc and pads) and all four tyres are brand new.
I read the double wrench service post and also had a look at the service schedule, but I'm hell confused - should I just ignore the double wrench and do standard?
Old May 16, 2015 | 06:07 PM
Bill F's Avatar
Default Re: Double wrench service confusion....
SCOPE OF WORK FOR “B” SCHEDULE MAINTENANCE SERVICE
Oil Change
² Change oil and replace filter
Maintenance
² Rotate tires
² Replace dust filter
² Lubricate hood hinges, latch, and secondary latch
² Reset FSS Display
Function Check
² Horn, hazard warning flashers, turn signals, and indicator lamps
² Headlamps and exterior lighting
² Windshield wipers and washer system
² Check seat belts for damage and proper function
² Test hydraulic brakes and check parking brake function
Inspection
² Check front and rear brake pads for lining thickness
² Check condition of front and rear brake discs
² Check tires for damage and general condition
² Check tire inflation pressures and correct if necessary
² Check major underbody components for leakage or damage (if there are signs of leakage, determine cause
and repair)
² Check condition of front axle ball joints and rubber boots
² Check condition of steering components and rubber boots
² Check underhood components for leakage or damage (if there are signs of leakage determine cause and repair)
² Check condition of accessory drive belt
² Check headlamp aiming, adjust if necessary
² Check windshield wiper blades, replace if necessary
Fluid Levels
Check fluid levels for the following systems and correct if necessary. Should there be a loss of fluid that cannot be
explained by regular use, trace and eliminate the cause.
² Engine cooling system (check corrosion inhibitor/antifreeze)
² Hydraulic brake system
² Power steering system
² Windshield washer system
Old May 17, 2015 | 03:15 AM
minimayhem's Avatar
Thanks...
Although my confusion isnt over what items should be done, it if it should be done at all as according to what I've read, I should have just had a double wrench service 4K miles ago, or have just had one when I bought the car.
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
4drturbo
Oct 2, 2015 12:58 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Selbyl
Sep 26, 2015 04:15 AM
Abaton6
Sep 24, 2015 10:14 PM
