New Headers
Old Aug 15, 2015 | 12:49 AM
NeedsWings's Avatar
Default New Headers
So back in June Squirellcrusher (Don) drops off his car and tells me that he is not going to pick it back up until there are headers on it Fair enough. The fire is lit. I finished the welding today on them, back purged TIG welded inside and out of the aircraft 304 stainless steel mandrel bent tubing on these one-off's for Don. They came out orgasmic!
Should flow 49.6% more than the factory manifold and bolt right up in its place to either the factory downpipes or our replacement downpipes
I had a factory manifold that I sliced up to measure the actual tubing that is inside the heat shields but I have been unable to find it today, I must have lost it in the move. I will end up slicing up another to show you the tiny tubing that your exhaust is flowing through right now. The factory primaries/collector/outlet are tiny and restrictive.
The set will still need to be gold ceramic zirconium thermal coated inside and out to keep the heat inside the pipe to not only keep the engine bay cooler but also keep up the exhaust gas velocity and again further increase flow/efficiency/power.
These have not yet been dyno tested as I just finished welding and porting them today. I will most likely dyno some yet to be built sets on local customer's NA and SRT6 cars as Dons car has many mods going into it right now so there is no solid before/after numbers to be had of JUST the headers being swapped on the car (he is also getting a full custom set of downpipes and catback coming in the next week or 2). I do expect some very impressive numbers to come out of his car though as it has several prototype parts on his engine that will all tie together very nicely including a prototype 90mm throttle body.
For your viewing pleasure, the first ever set of direct replacement, high flow headers for the Chrysler Crossfire Base, Limited AND SRT6, as well as the Mercedes SLK32 AMG and SLK320.
Old Aug 15, 2015 | 12:50 AM
NeedsWings's Avatar
Default Re: New Headers
2nd post saved for future pictures
Old Aug 15, 2015 | 01:07 AM
austinbarrylee's Avatar
Excellent Rob. Thanks for everything you do.
Old Aug 15, 2015 | 02:02 AM
The srt6 the guys need this ,i knew u could do it Rob,,, thanks ,,just in case i get another 6 soon. jim
Old Aug 15, 2015 | 07:46 AM
Sweet2002's Avatar
Very nice Rob. Looking forward to the results in numbers.
Old Aug 15, 2015 | 08:59 AM
Squirrel Crusher's Avatar
Smile Re: New Headers
Yes they look Orgasmic. You can't rush a great job. I knew I was dropping my car off at the right shop. Squirrel Crusher
Old Aug 15, 2015 | 09:50 AM
gblack32's Avatar
Subscribed
Old Aug 15, 2015 | 12:12 PM
Well Rob only the dyno well tell if your skills were put to good use. Standing by.
Old Aug 15, 2015 | 05:42 PM
MI1XFIRE's Avatar
Nice job Rob. Sorry I didn't make it to Lisa's last night to see them in person
Old Aug 17, 2015 | 05:39 PM
Hey Rob..If you need a pair of stock exhaust manifolds to cut up,then use mine. I have others in my stock pile. Squirrel Crusher
Old Aug 17, 2015 | 06:50 PM
NeedsWings's Avatar
already sliced another one up
you can see in the 4th image I set a small slice of the tubing I am using over the factory size to see the difference
File Type: jpeg
File Type: jpeg
File Type: jpeg
File Type: jpeg
File Type: jpeg
File Type: jpeg
File Type: jpeg
Old Aug 17, 2015 | 07:05 PM
Da55id's Avatar
Subscribed
Old Aug 17, 2015 | 08:40 PM
stryfox's Avatar
Ok so when can we order these.
Old Aug 17, 2015 | 11:20 PM
JEFASOLD's Avatar
Did I miss something or what? What do you think a set will set us back. Just when I thought I was done working on "The Ghost"
Old Aug 17, 2015 | 11:32 PM
deltacrossfirebob's Avatar
subscribe
and for a NA???
Thanks for the great work Rob.
Old Aug 18, 2015 | 11:42 AM
Selbyl's Avatar
Shut up and take my money!!
Old Aug 18, 2015 | 12:32 PM
meh03's Avatar
Subscribed for the dyno and cost. Sure look purty...
Old Aug 18, 2015 | 01:54 PM
JHM2K's Avatar
Subscribed. Because reasons.
Old Aug 18, 2015 | 06:45 PM
Binky's Avatar
No price and availability ? That's downright rude? ... Where do i sign up? How much? Pleeeeeeeese I need a pair.
Old Aug 18, 2015 | 07:49 PM
don't know what they will give the 6, but Rob, Rudy, and JS benz did my v8 a little over a year ago. I went from 11.05 to 10.8 then we went with 3" exhaust to the srt 6 muffler ,,,i went to 10.7 then the killer chiller it went to 10.6 so you can see the headers made the best improvement , and these are much better than i have. IF I EVER BUY A SRT6 SIX that is i will have these headers on it. jim
I don't do dyno's
