BAS/ESP light and less power
Old Aug 18, 2015 | 07:40 PM
velociabstract's Avatar
Default BAS/ESP light and less power
My turn for a bit of head scratching. At the track on Sunday, I felt a loss of power. It was on the straight around 100 mph or so at WOT. No noises, just felt like the computer pulled lots of timing. Checked the Dashdaq and the temps were OK. I finished the session practicing my driving and didn't think much of it. Swapped back to street tires and moved the car from the paddock to the public parking area so I wouldn't get trapped inside until late in the day. There was a noise coming from the transmission area, I believe, a sound that could be a vacuum leak, but more of a musical tone. Again I didn't think much of it. Pulled out of the parking and found I had no real power. It felt like the throttle body was only opening 10% even with the pedal to the floor. Exhausted, I drove the 1 1/2 hours home with the ESP/BAS light on. No drama crossing the mountains, just N/A type acceleration ... or worse. Today when I got a break I checked for codes. None. The light is off. The car has "more" power but nowhere near 100%. No noise or singing today. What's my problem? I'll be digging in on Saturday, most likely, but not sure what I'm looking for. I have a spare throttle body in case what's on the car is fried. I'm open to suggestions. Help me make a list and to work "smart". I'll check the boost and timing with my dashdaq before taking things apart. Maybe I'll find some indicators.
Les
Old Aug 18, 2015 | 07:44 PM
Default Re: BAS/ESP light and less power
Symptoms: ESP/BAS light and extreme power loss: now no light just 1/2 power: whine or tone from somewhere ..... now gone. NO CODES. Scratching head and looking for cheap Rogaine.
Les
Now that I'm relaxing at home …. the idle was a bit higher than normal while making the "sound". Now, no sound and normal idle.
Old Aug 19, 2015 | 07:04 AM
Check the vacuum line that goes from the rear of the manifold into the firewall via a plastic tube - these get brittle and break. ( Not sure what this line does, I think the other plastic tube that runs under the battery tray does the A/C vent stuff, and heck, this could even be the same line, probably is )
Old Aug 19, 2015 | 07:43 AM
Good idea! I'll check the hoses under the supercharger and battery tray too.
Les
Old Aug 19, 2015 | 10:09 AM
Mrmiata's Avatar
It is the same.. and I might add a favorite of mice on the Crossfire menu.. LOL.
After multiple splices with a rubber line.. I added a stainless steel braided sleeve on it.. No longer on the menu..
Old Aug 19, 2015 | 10:43 AM
Have you ever thought of getting a cat ?
Old Aug 19, 2015 | 10:50 AM
Mrmiata's Avatar
Had 3 dumped off here.. disappeared .. must make a good coyote snack.. LOL.
Old Aug 19, 2015 | 12:53 PM
Maybe the coyote's will develop a taste for rats/mice since the cats are gone........
Old Aug 23, 2015 | 12:03 PM
I had a long interesting post ready and accidentally left the Forum messing with an email. Drat! So now a boring version of todays investigation. It's a leak, most likely at the throttle body, lower Y pipe hose or the supercharger to intercooler gasket. The engines AFR's are low 13's at WOT and I'm missing 75 hp, or more. After going WOT a couple of times the "tone/whine" returned and the idle was a bit high. It was too hot to dig in but the whine was from the throttle body/Y pipe area as far as I could tell. The car was idling fine until going WOT so my guess is some hose or joint unsealed at high boost post supercharger. Loss of hp points to a boost leak too.
All the hosed checked out. Brake booster hose, hoses under the supercharger, pvc/catch can hoses … the one under the battery tray doesn't hold vacuum but I don't know if it should or not. The A/C and brakes are working correctly.
Les
Old Sep 2, 2015 | 12:07 PM
Lets see if you can hear the "tone" on this quick video. I did find the pvc hose falling off the throttle body, fixed it and the car runs "better" but not at full power and while the loud leak is gone I still have one. It seems to be on the drivers side around the Y or under the supercharger. The BAS/ESP light hasn't come back. I guess it all has to come off.
Les
File Type: mov
Old Sep 5, 2015 | 10:48 AM
Had to take the manifolds off to find the problem. Something I truly wanted to avoid. One of the clamps that connect the Y to the intercooler snapped. All that's left is to re assemble with care and I should be good to go.
Les
Old Sep 5, 2015 | 12:03 PM
All back together without drama. Tomorrow after the locktite sets I'll go for a test drive. I'm getting good at remove / replace. A morning with a trip to the parts store for some clamps in the middle and done before lunch.
Les
Old Sep 7, 2015 | 01:47 PM
Car tested and at 100% once again. Sometimes the fastest way to find a problem is take things apart. Darn BAS/ESP and no trouble code is what had me scratching …… not cat scratch ….. for my problem consultants.
Les
Old Sep 7, 2015 | 02:06 PM
Good to hear Les, appreciate you not getting upset over the non subject matter interplay between mrmiata and I.
Sometimes I just can't help myself
Old Sep 7, 2015 | 03:22 PM
I rarely get upset and don't mind when things get out of hand. I've seen too many get upset and leave, sadly. We need everyone from the arrogant, stubborn, foolish, young, old ……. english comprehension majors, drama queens, debaters, diçks, etc. Everyone has something useful they can contribute ….. eventually.
Les
Old Sep 7, 2015 | 03:43 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Les
Well said Les.
However this is like Hotel California.........You can check out any time you like,
But you just can never leave!'
Glad you found the cause of your issue.
jgreen
106
Sep 18, 2017 11:46 PM
gp1200x
Dec 6, 2015 12:59 PM
xfClifford
27
Nov 10, 2015 10:08 PM
axnguyen
Jul 21, 2015 11:41 AM
Blackout317
Jul 7, 2015 08:38 PM
