hood scoop.
Old Oct 1, 2015 | 09:30 PM
steps's Avatar
Default hood scoop.
Has any modified the hood to put functional scoop on it?
thanks
Old Oct 2, 2015 | 01:04 AM
+fireamx's Avatar
Default Re: hood scoop.
Steps, all I need to do to make my scoop functional is remove the inserts that sit behind the mesh covers. I chose not to for several reasons. Even though opening it up would allow some cool outside air under the hood to help alleviate heat soak, I really don't think it's necessary since I don't have a pressure cooker/supercharger to heat things up.
If I wanted to use it as a cold air introduction system, I'm pretty sure it wouldn't work nearly as well as the NeedsWings CAI.
I had mine built purely for looks, and it's met and surpassed all my expectations.
If you're looking for some under hood heat removal, I'd suggest taking advantage of the high pressure area at the base of the windshield by installing a cowl induction scoop there, Something like the 1969 Camaro used. Good Luck.
Old Oct 2, 2015 | 06:59 AM
waldig's Avatar
Talking Re: hood scoop.
Here is the easiest start, Woody
PS I made my own Va. accepted hood NEGATIVE hood scoop = see my gallery for details.
https://www.crossfireforum.org/forum...econd-fix.html
Old Oct 3, 2015 | 11:00 PM
ZX2 Nick's Avatar
To be functional you could (would) have 2 NACA ducts way on the leading edge of the hood to feed air air into the OEM airbox/engine cover.
http://www.dsgperformance.com/assets...rmance%203.jpg
http://image.hondatuningmagazine.com...naca_ducts.jpg
Old Oct 3, 2015 | 11:15 PM
They may look OK on a Honda but not on a Crossfire, the Jaguar ones look much better.
Old Oct 4, 2015 | 09:01 AM
waldig's Avatar
My hood is to exhaust the engine heat, the intake air is in front of the radiator. My scoops are not even noticable to the casual observer, thats good too and they are 100% functional and tested.
Old Oct 4, 2015 | 11:37 AM
americanretrodave's Avatar
I love the looks of the Crossfires, Coups or Roadsters, they are all beautiful. That being said, Chrysler incorporated their signature hood on them; my guess to keep it connected to their line up. To me, it's the weakest part of the design. I would have preferred the multiple side curves removed with just a center ridge remaining. A hood scoop would have been better yet. I had a '70 Cuda after I got back from Nam, I would have really appreciated similar hood scoops on the Crossfire, especially the SRT6. I may pick up a used hood to play with, it's not a high priority but it has been hanging around a bit.
I've always enjoyed Fireamx's hood.
Dave
Old Oct 4, 2015 | 11:30 PM
ZX2 Nick's Avatar
I think it would help if you took the images that I included absolutely literally without thinking that they were representational images intended only to show 2 types of NACA ducts.
What Jaguar ones?
Old Oct 5, 2015 | 08:21 AM
What Jaguar ones?
What is the sense of adding pictures if they are not of what you speak?
Use search to look for Jaguar vents.
Old Oct 5, 2015 | 11:37 AM
ZX2 Nick's Avatar
What part of "representational images intended only to show 2 types of NACA ducts" is difficult to understand?
The images I referenced are of what I speak, though there many, many, many other iterations of NACA ducts.
I found Supercharged hood vents (Jaguar) on this site and they are certainly not NACA ducts.
Old Oct 5, 2015 | 01:23 PM
Crossfires fly but not in the air, so I'm missing your point still.
Old Oct 13, 2015 | 09:40 PM
steps's Avatar
thanks to every one who responded to my questions it definitely gives me a lot to think about.
Thanks all.
Charlesl
Sep 30, 2015 10:46 PM
dizzy
Aug 18, 2015 03:57 AM
waldig
Jul 29, 2015 06:54 AM
Jul 25, 2015 08:01 AM
jonnyangel04
Feb 24, 2008 10:46 PM
