No Fastener Front License Plate Mount
Old Oct 26, 2015 | 06:54 PM
ATX SRT-6's Avatar
Default No Fastener Front License Plate Mount
Living here in Texas state law sez ya gotta have a front license plate or risk a $200.00 fine. I didn't want to drill no stinkin' holes in my bumper so today I came up with a way to mount a front license plate on our Crossfires' without using fasteners.
First thing is get the OEM front license plate holder part number 0YA51XS9AA
Then get these Frog Feet Suction cups off Amazon. These cups have some sticky reusable polymer on the edge and hold really well. Plus the diameter is just right without protruding past the edges of the holder.
Amazon.com: FrogsFeet Large Suction Cups with Hooks, 4-Pack: Office Products Amazon.com: FrogsFeet Large Suction Cups with Hooks, 4-Pack: Office Products
Once you have the cups remove the hooks off of two of them with some needle nosed pliers.
Drill two 1/2" holes in the recessed areas on the license plate holder. A Unibit works great for this.
Push the suction cups into the hole from the back. It's a very tight fit but a little silicone spray makes it easier.
Drill the 4 holes into the holder to mount the plate and install that.
Clean any wax, bugs etc off the front of the bumper.
When you go to stick the holder on make sure the little pull tabs are facing towards the sides. I found that if you hold them out while pushing the center it lays flatter.
Make sure the bottom edge of the suction cup is not hanging below the lower character line of the bumper or it won't stick for long.
The top of the holder should be about a 1/4 above the top character line.
For safety run two 11" zip ties through the plate and the lower grill
Stand back, drink a beer and enjoy your new license plate holder.
Old Oct 26, 2015 | 07:02 PM
Default Re: No Fastener Front License Plate Mount
As long as it hold this looks like the cleanest way I have ever seen posted to mount our front plate and holder without and hardware screwed in anywhere
Old Oct 26, 2015 | 07:21 PM
maxcichon's Avatar
Nice!
I was speaking to Franc about this at the Dragon earlier this month. I saw this on an ad:
No Holes License Plate Bracket - F10 5 Series 2011+. F07 5 Series GT - Turner Motorsport
$80 is a bit...pricy. Even for a BMW-targeted part. BUT, anyone with skills should be able to make one for themselves for ~ $20.
It uses the recovery hook for the mount. You just have to come up with a hook/screw to attach it. Go from there.
A small u-bolt to attach and build from there.
Just a thought.
Old Oct 27, 2015 | 03:08 PM
ATX SRT-6's Avatar
Thanks,
These Frogs Feet cups really do stick. I decided to try them after reading the reviews on Amazon. And to make sure the cups stuck to the bumper I slid a butter knife behind the holder and pressed down on the cups. So far the license plate is holding in place just fine.
Old Oct 27, 2015 | 08:40 PM
RED DOG's Avatar
WOW! I LIKE IT! I've had all the parts I need to put a RED DOG plate on the front of my black rescue roadster but I didn't want to drill holes into the front bumper. THANKS for the solution. I'm on it!
Old Oct 27, 2015 | 09:28 PM
Really great idea. But kinda risky of loss IMO. You may want to refasten it once in a while.
My mother uses the suction cup hand rails in her shower. About every two months they get loose.
If I have to go with a front plate, I think a bracket could be fabricated to attach to one of the lower grilles.
James
Old Oct 28, 2015 | 10:22 AM
ATX SRT-6's Avatar
You should try the Frog Feet, the inventor had the same problem in his bathroom and that's how he came up with the idea.
FROG's FEET
Why FrogsFeet?
We developed FrogsFeet™ suction cups because regular suction cups that we were using on a newly designed bath product kept failing in tests on a presumably smooth surface. Upon closer inspection we discovered that the surface was in fact slightly textured, causing the lip of the cup to lose its seal and therefore the ability to maintain suction. After much development and testing we came up with a suction cup that makes just about every other suction cup obsolete. FrogsFeet™ have a revolutionary active polymer seal around the lip that conforms and bonds to a wide variety of nonporous surfaces, from smooth to highly textured. Combining the principles of suction and adhesion FrogsFeet™ can support more weight and tension by maintaining maximum suction over astonishingly long periods of time. They stay put in temperature extremes because the polymer seal compensates for expansion and contraction. They will not let go or slide in moist or wet environments such as bathrooms because the hermetic seal keeps moisture from penetrating the lip and entering the interior of the cup. This makes them ideal for prolonged outdoor use, in heat and cold, rain and snow. Regular suction cups will fail on all counts.
I imagine a zip tie could be added easily enough for extra security. Put two small holes centered along the bottom front of the holder an inch or so apart and wrap the zip tie(s) through it and around the center part of the valance.
Before this idea I had the plate mounted using long molly bolts going through the lower grill. State law in Texas says it has to be centered and 12" off the ground so there's only one place to put it. Didn't look so great because of the shape of the bumper and since you can only use the bottom holes in the plate it leaned forward.
Old Oct 28, 2015 | 10:53 AM
pioneer4x4's Avatar
Maybe using the "Command Strips" product, and a safety tether. I have had success, even on wood, with them. I would be afraid of the plate coming off and running over it on the highway, that could cause SEVERE damage to you or another person getting hit by a license plate at over 50mph.
Old Oct 28, 2015 | 01:46 PM
ATX SRT-6's Avatar
I ran two zip ties through the existing holes in the license plate. If both cups were to fail this should keep it safely attached to the car. Plus slow down anyone that might try and steal it.
Old Oct 28, 2015 | 02:59 PM
I guess my 93 Caravan was illegal in Texas. That is the factory location of the tag.
Old Oct 28, 2015 | 03:57 PM
ATX SRT-6's Avatar
There was a court ruling in Texas that found the plates had to be mounted "where the car begins, i.e. on the foremost area of the vehicle". TAWIN SPENCE v. THE STATE OF TEXAS | FindLaw
And it has to be 12" from the ground in Texas.
(1) must display two license plates, one at the exterior front and one at the exterior rear of the vehicle that are securely fastened at the exterior front and rear of the vehicle in a horizontal position of not less than 12 inches from the ground, measuring from the bottom, except that a vehicle described by Transportation Code, §621.2061 may place the rear plate so that it is clearly visible;
Would yours pass in Texas? I'm not sure after reading that court ruling. One thing for sure is the license plate laws in Texas are confusing a best. I'd rather not give any reason to get pulled over if I can.
Since the Crossfire OEM holder is designed for the center of the bumper that's where I put mine.
Old Dec 1, 2015 | 08:21 AM
ATX SRT-6's Avatar
Just an update on the license plate mounting,
It's been over a month and several hundred miles and it hasn't moved one bit.
Old Dec 1, 2015 | 09:28 AM
I have just noticed this post, up here the licence plate frames are attached by the dealer and the frames are in the trunk on delivery to them. I always assumed that this allowed the cars in those jurisdictions that did not require a front plate to be not marred by screw holes.
I have had cars where the plate was not square or centered.
Old Dec 1, 2015 | 10:13 AM
pioneer4x4's Avatar
Yeah, in Pennsylvania, front plates are not required. I hate getting a car that has been drilled for front plate and has a cheap factory plastic mount riveted to the front bumper cover. Luckily, my Crossfire is intact, my 2013 SRX had one, I removed it and got the little plastic trim plugs, and touch up painted them to cover the holes.
My 1967 El Camino has plate holes and a flat spot on the front chrome bumper, so I mounted a 3rd party plate there.
I liked the 90s Pontiacs (I think) with the removable center trim for a plate.
Old Mar 30, 2016 | 01:53 PM
ATX SRT-6's Avatar
Update: my front plate hasn't budged since I put this on almost 6 months ago
Old Mar 30, 2016 | 03:30 PM
James
That's how I did it.
Long allthread rods, some toggle nuts washers and standard nuts. Push the toggles thru the grill tighten, the washers down, add the plate and yer off.
All from the local hardware at less than five bucks.
Geechee1962
Nov 24, 2015 05:55 PM
got2cxfires
Oct 27, 2015 01:44 PM
BlueFire
Oct 22, 2015 05:27 PM
crossfireE
Oct 2, 2015 01:40 AM
Billy22Bob
Oct 1, 2015 05:34 AM
