replacing seat relay
Old Dec 27, 2015 | 06:49 PM
steps's Avatar
Default seat relay
Well I'm have problems with my seats now..
I move them to an upright position to clean behind them and now they don't move. really pissed can barely fit in to drive what do in need to do take it to a Stealer?????
Old Dec 28, 2015 | 10:31 AM
Default Re: seat relay
I take it you have tried to move them ;
1, With the driver door open and ignition off and on?
2, With driver door closed and ignition off and on?
Did you check the fuses #21 and #22 under the hood
Did you make sure that the plugs under the seats had not come apart even just a little?
If you push the door switch down with the engine off, can you here a relay under the dash click? If you have good ears you can hear it, if you are as deaf as me you will need to put your fingers on the seat relay and feel the click. It will click when you push it down and when you let it pop out again.
Click here for the .pdf on seat relay location.
Old Dec 29, 2015 | 11:03 AM
steps's Avatar
thanks can't hear either,r it worked intermittently. I ordered a relay on ebay I now need to figure how to remove panel? where are all the screws? I only see two?
Thanks I copied the pdf
Checked 21 22 all good
Thanks
onehundred80
Dec 27, 2015 05:03 PM
Valk
Dec 22, 2015 05:18 PM
rgw9707
Dec 12, 2015 05:57 PM
Red Runner
Dec 5, 2015 04:56 PM
