How often do you empty your Needswings PCV catch can?
Old Feb 8, 2016 | 10:24 PM
boostmonkey's Avatar
Default
I have halfway installed one. It was a tight fit, but very nice part.
File Type: png
Old Feb 8, 2016 | 10:27 PM
Default
Pic of catch can
Old Feb 8, 2016 | 10:49 PM
syfi's Avatar
Default Re: How often do you empty your Needswings PCV catch can?
I'd say to check it every other oil change....
Old Feb 9, 2016 | 12:09 AM
deltacrossfirebob's Avatar
It is easy so I do it with every oil change.
Old Feb 9, 2016 | 06:18 AM
Originally Posted by boostmonkey
Pic of catch can
Attachment 36842
Nice !!!
( you have a nut missing off that A/C pipe clamp )
Old Feb 9, 2016 | 08:25 AM
I empty mine at each oil change
This is what it has collected most every time
Old Feb 9, 2016 | 09:10 AM
NeedsWings's Avatar
please drain at every oil change
Old Feb 9, 2016 | 10:27 AM
Fla_Xfire_SRT's Avatar
So, wheres that oil going when there is no catch can (stock)? Do both engines (SC/non) take an advantage when using the catch can? Is this primarily for folks who race their Crossies at a track? Thanks in advance.
Old Feb 9, 2016 | 11:03 AM
Default
Without the catch can the oil goes into the throttle body to be burned with the fuel ultimately overtime clogging up the throttle body
This occurs under normal driving conditions for all crossfires
Old Feb 9, 2016 | 11:12 AM
JimmieC's Avatar
I checked mine monthly and found nothing. At the oil change I ran a tooth pick up the hole and it drained out about 3 ounces. Evidently it can get plugged with ctud at the drain.
Old Feb 9, 2016 | 09:11 PM
Default
Thanks everyone. I will check it each oil change.
RED DOG
Jan 30, 2016 07:35 PM
brandoni
Jan 21, 2016 01:03 PM
Timesnow
Jan 18, 2016 10:18 PM
kstewart
Jan 12, 2016 11:02 AM
Wolf_7
Dec 30, 2015 08:17 AM
