MP3 player on stock audio unit very easy without changing the radio!
Old Feb 21, 2005 | 10:20 AM
Steffen's Avatar
Default MP3 player on stock audio unit very easy without changing the radio!
Do you want connect an MP3 player on your stock radio? You don’t need to install an other expansive radio.
I have seen on the SLK forum in Germany a perfect tool that you connect with the stock head unit. On that tool you can connect your MP3 Player with the ear phone connection. The tool you connect on the stock car radio antenna. The MP3 Player gives out the music on the ear phone connection then it came into the tool and the tool gives it into your car antenna (like the XM commander). Now you search on the FM frequency band on your stock radio if you hear the MP3 then safe it on one of your radio buttons. That is all. You can connect all audio units that have an ear phone output.
Here is a link for the installation of that tool. The instruction is in German but the pictures say all.
http://www.mbslk.com/files/artikel/thbmp3.pdf
Old Feb 21, 2005 | 02:08 PM
CyberGreg's Avatar
Exclamation Re: MP3 player on stock audio unit very easy without changing the radio!
Edit After translating to english, it looks like it is an FM Modulator of some sorts. It might work with our standard radios. Steffen, fo you know of anyone with a Crossfire that has used this?
Old Feb 21, 2005 | 02:27 PM
pnsji's Avatar
Default Re: MP3 player on stock audio unit very easy without changing the radio!
check this out:
http://frontiernet.net/~dbipes/SLK/m...pter/index.htm
Old Feb 21, 2005 | 06:28 PM
CyberGreg's Avatar
Cool Re: MP3 player on stock audio unit very easy without changing the radio!
Originally Posted by pnsji
Beofre buying that you might want to check out this thread. SeaXfire was not able to get the BIPES adapter to work.
Old Feb 21, 2005 | 08:21 PM
cgates's Avatar
I bought a FM modulator from Crutchfield and connected to the stock head unit in my Crossfire, it works fine
Old Feb 22, 2005 | 12:50 AM
pnsji's Avatar
so it looks that the problem is that the amp is turn on/off by turning on/off the head unit. What you can do is to wire the remote turn on amp with ignition. So everytime the car is on, the amp is on. Then either radio or ipod, does not really matter.
Old Feb 22, 2005 | 02:06 AM
CyberGreg's Avatar
Yup, that would do it, as long as you don't get that anoying amp pop. Although, even if that happened I've seen timers that can correct that problem too.
I just don't like it because it bypasses the head unit so you have to control the volume with the device. But hey it would do the trick.
pioneer4x4
Sep 18, 2023 11:49 AM
PNA
Nov 12, 2020 04:44 PM
pioneer4x4
Jul 27, 2015 02:04 PM
xzmilan
Jul 22, 2015 10:40 AM
axnguyen
Jul 21, 2015 11:41 AM
