Another BAS/ESP Conundrum
Old Mar 6, 2016 | 04:27 PM
Kaktis993's Avatar
Default Another BAS/ESP Conundrum
Howdy everybody! This is a great forum with tons of helpful info. I posted this issue in another thread but figured I'd start my own for a little more exposure.
My wife's '04 has had the BAS/ESP light on for a while now. We're fixng on selling the car, so it's in the shop and they're trying to troubleshoot the source of the light, but apparently the car is not throwing any codes whatsoever. Sounds like they've tried both OBD as well as the Mercedes diagnostic tool.
Anybody know what could cause this? Also, the brake pedal has been mushy for a while, can't help but to wonder if that's associated with the BAS/ESP? I've tried all the simple fixes: new battery, steering column switch reset, brake light switch must work because the brake lights work. Could a burnt out turn signal cause this??
Someone mentioned earler that the mushy brake could be the culprit, does anyone else have any experience with this happening?
Thanks!
Old Mar 6, 2016 | 08:04 PM
Bill F's Avatar
Default Re: Another BAS/ESP Conundrum
Have you tried this:
Synchronizing ESP
If the power supply was interrupted (battery disconnected
or discharged), the BAS/ESP malfunction indicator
light may be illuminated with the engine running. To
re-synchronize the ESP, and cancel the malfunction indicator
light, the steering angle sensor will need to be
recalibrated.
1. Turn the ignition switch to the ON/RUN position.
2. Rotate the steering wheel to the center position.
3. Rotate the steering wheel completely to the left, and
then rotate the steering wheel completely to the right.
4. Bring the steering wheel back to the center position.
5. The BAS/ESP malfunction indicator light will go out.
If the BAS/ESP malfunction indicator light is still illuminated,
the vehicle should be serviced at an authorized
dealer.
Old Mar 6, 2016 | 08:17 PM
Synchronizing ESP
re-calibrated.
dealer.
This will usually work but I do this procedure with the car running and if the light does not go off immediately I drive a mile or two and the BAS ESP light will reset and turn off
Old Mar 6, 2016 | 09:12 PM
Thanks!
Could be a wheel speed sensor.
Old Mar 7, 2016 | 10:38 AM
Kaktis993's Avatar
Synchronizing ESP
recalibrated.
dealer.
Hi Bill, I gave that a try with the engine off and key in run, and then also with the engine running. No luck either way. Thanks though, I appreciate the suggestion.
Old Mar 7, 2016 | 10:39 AM
Kaktis993's Avatar
Intersting theory, I'll have the shop look into that. Thank you!
EastCoastSteve
Dec 30, 2015 06:53 PM
dedwards0323
Detail Shop
Dec 27, 2015 06:27 AM
toob
Dec 18, 2015 08:30 PM
barber
Dec 12, 2015 12:37 PM
JoeP
Dec 9, 2015 10:10 AM
