Brake light stays on when I turn the lights on
Old Apr 4, 2016 | 09:52 PM
ashkanmo's Avatar
Default Brake light stays on when I turn the lights on
Hi everyone.
My left taillight went out again it was going in and out) so I decided to check the light bulb with another light bulb. My mistake was to keep the switch on when I was check in it. after I figured the connection is bad my brake lights stayed on. It stays on when I have my headlights on and it works fine when lights are off. I checked all fuses. everything is fine. I am not sure what I should look for now.
Old Apr 4, 2016 | 11:19 PM
Default Re: Brake light stays on when I turn the lights on
Be sure you have the correct bulb, and that the bulb is installed properly.
Old Apr 25, 2016 | 05:31 PM
Eco's Avatar
Eco
I've got the same problem, any help guys/girls ?
Old Apr 25, 2016 | 06:35 PM
Did you just put in a new bulb?
Problems have occured when the wrong bulb was installed as noted in post #2.
The wrong bulb makes the wrong contact in the socket somehow.
Make sure it is the correct bulb, the correct bulb only goes in one way.
Old Apr 25, 2016 | 11:08 PM
kingdavid54's Avatar
I agree with 180 sounds to me like you have the wrong bulb or you have installed it wrong.
Old Apr 25, 2016 | 11:18 PM
JSK's Avatar
JSK
Wrong bulb or open ground to that light assembly.
Old Apr 26, 2016 | 05:25 PM
WindRestrictor's Avatar
Former Vendor
Welcome to the forum. You're in the right place for help.
Old Apr 27, 2016 | 02:31 PM
Eco's Avatar
Eco
Love this forum. Swapped out the Bosch bulbs for GE and problem solved. Same spec but the GE seemed to fix the issue. Thanks .
Dcwhite67
Aug 5, 2017 10:31 AM
matcail
58
May 2, 2016 01:29 PM
sastrom
Apr 3, 2016 11:44 AM
LarryDamm
Mar 30, 2016 11:14 PM
mobilefitt
Mar 30, 2016 09:19 AM
