Mercedes engine cover
Old Apr 8, 2016 | 12:01 AM
MB04XFIRE's Avatar
Default Mercedes engine cover
I am looking to put in a needswings single CAI.
I have a Mercedes engine cover.
I was wondering if the engine cover is a direct swap on our NA xfires, or if we need to modify it in any way.. On the needswings they write on the one they sell that they do the needed trimming to drop onto the xfire... What are they Refering to as to these trimmings?
Any help would be great.
Thanks
Old Apr 8, 2016 | 07:47 AM
Billto's Avatar
Default Re: Mercedes engine cover
Thanks
Contact them, they are very helpful.
Old Apr 8, 2016 | 05:33 PM
You have to trim the front a bit to clear the radiator hose.
Old Apr 10, 2016 | 05:00 PM
MB04XFIRE's Avatar
Oh ok perfect thanks.
For engine cover removal does it just clip on, just pull it off I assume?
Old Apr 10, 2016 | 05:34 PM
Yep, but only 3 points, 2 on driver side, one on passenger side.
The rear point on passenger side is not used, and the front clip thingey on the air pump is not used.
Old Apr 10, 2016 | 05:40 PM
MB04XFIRE's Avatar
Awesome thanks
Old Jun 9, 2016 | 04:08 PM
crazyfred's Avatar
I also picked up the Mercedes engine cover. I notice that there are no provisions to attach the factory air cleaner boxes to the cover.
What up with that?
Old Jun 9, 2016 | 04:34 PM
If you are talking about the cover pictured below, then MB had a tube running from the TB to the air cleaner on the E320's this come off of.
You should only use this cover if you have a single or dual CAI kit.
IMG 0980
You can see an image of it on an E320 here : https://www.searchlock.com/mirror/p?...e/44871827.jpg
Old Jun 9, 2016 | 04:53 PM
crazyfred's Avatar
IMG 0980
Thanks for the reply. The factory cover has 2 air cleaner boxes attached to the bottom and two pipes
that go the collector in the grill area. The Mercedes cover fits the engine, but what do I do for an air cleaner and related piping?
Old Jun 9, 2016 | 05:56 PM
Pictured in IMG 0980 is my engine with that cover and a NeedsWings single CAI.
Old Jun 9, 2016 | 06:16 PM
If you use that engine cover you are obliged to use the setup shown in the picture, the filter is out of site in front or the radiator.
Old Jun 9, 2016 | 08:07 PM
crazyfred's Avatar
MI1xfire has the set up I like. I was just wondering where he got the parts. I would like chrome pipes though. I have the same cover
Old Jun 9, 2016 | 08:48 PM
crazyfred's Avatar
Ok I found it. Needswings. But wow, the price stopped my heart!!. Looks like a well made set-up, but I don't have the dinero right now. Anybody know of anything cheaper that will work with that cover?
Thanks in advance.
Fred
Old Jun 9, 2016 | 08:57 PM
You can buy a bunch of parts and cobble one together, but the rub comes where you need to mount the IAT/MAF sensor, unless you retain the 2 OEM plastic pieces and attach the tubing to that.
Some members, like maxcichon were very successful with that approach, but then his doesn't allow for that engine cover : https://cimg4.ibsrv.net/gimg/www.cro...a936b18f36.jpg
4drturbo
Dec 22, 2018 10:19 PM
bbsrt6
Sep 16, 2017 04:37 PM
4drturbo
Apr 14, 2016 11:58 PM
patten316
Apr 6, 2016 12:44 PM
UrbanE
Apr 3, 2016 09:41 PM
