2005 Crossfire sputtering on takeoff
Old May 23, 2016 | 08:39 PM
Dillonwass's Avatar
Default 2005 Crossfire sputtering on takeoff
Hello please help I have a problem with my 2005 Crossfire sputtering on take off and on low rpm's. On the freeway it feels like when I step on it if cuts out a bit too. It's like when I accelerate too quickly it always happens. I don't know where to start I used a scanner and it says random cylinder misfire on 3,4&6... When I stand behind the car it smells like excess gas coming out of the exhaust.. It's a manual coupe v6.
Please help thanks guys
Old May 23, 2016 | 08:47 PM
Default Re: 2005 Crossfire sputtering on takeoff
Sounds like it's running rich or choking on clogged air filters. Also, you told us all about your car but for one thing: how many miles?
Between 75000 and 100,000 miles, the car needs plugs and plug wires. I had misfire and O2 sensor codes along with sluggish performance - put in 12 plugs and 12 plug wires and ALL codes went away; and the car ran like it should. It went down hill so slowly, I'd not realized how sluggish it had become.
(THis was the middle car pictured below, just FYI)
Old May 23, 2016 | 08:49 PM
I"m wondering what a filthy or just BAD MAF would do as well.
Old May 24, 2016 | 07:16 AM
Could also be a vacuum leak ......
Old May 24, 2016 | 06:43 PM
Mike-in-Orange's Avatar
My '05 Coupe started to stumble a bit when stopped for a light, even threw a CEL which came up as related to Throttle Position Sensor. I did a bit of research online and came upon this article: P0121 - OBD-II Trouble Code
So I took that bit of advice to heart, picked up this kit (
Amazon.com: CRC MAF & Throttle Body Single-Use Twin Pack, 1 Kit: Automotive Amazon.com: CRC MAF & Throttle Body Single-Use Twin Pack, 1 Kit: Automotive
) and spent a few minutes cleaning the MAF and throttle body. No more stumbling at stoplights or hesitation when getting on the throttle.
JOE6C
May 26, 2016 06:16 PM
canadablue
Apr 25, 2016 07:44 PM
hotwheels
Apr 13, 2016 08:36 PM
carmjr1
Mar 27, 2016 01:23 PM
Dave F
Mar 15, 2016 05:03 PM
