Loss of power
Old Nov 2, 2016 | 08:13 PM
bucksarrow's Avatar
Default Loss of power
AT about 100mph in 4th gear My srt6 just flattens out and refuses to accelerate any more also the pa esp light light came on. Possible cause? thanks
Old Nov 2, 2016 | 08:40 PM
Rpaczan's Avatar
Default Re: Loss of power
Some similar postings describe an issue with CPS
https://www.crossfireforum.org/forum...tml#post851581
Also, a posting here with BAS ESP light and acceleration issue indicated a wiring harness issue with throttle body.
https://www.crossfireforum.org/forum...elerating.html
One more for your....points at possible vacuum line issue. Owner had broken connector to inter cooler.
https://www.crossfireforum.org/forum...ess-power.html
Old Nov 5, 2016 | 06:32 PM
bucksarrow's Avatar
Rpaczan
Thanks you have been very helpful.
bucksarrow
Old Nov 6, 2016 | 08:11 AM
I haven't had this happen in awhile, but while testing at the track, I have had the throttle pedal come unhinged and ride up on the mounting. This will result in less that full throttle. I know this isn't your problem but may be a problem in the future if you do many full throttle launches. Might try a throttle reset. See if it helps.
Old Nov 6, 2016 | 10:31 AM
bucksarrow's Avatar
thanks I will give the throttle reset a try.
Old Nov 6, 2016 | 04:48 PM
I remember a post where something like this happened because of tire sizes, what size tires do you have and are they all the same diameters side to side?
