Broken grounding point screw
Old Nov 5, 2016 | 02:32 PM
thedarkfox's Avatar
Default Broken grounding point screw
Just went to add an additional ground wire and snapped the grounding point screw on the drivers side right off. Can I simply drill a new one into the chassis right beside it?
Thanks
Old Nov 5, 2016 | 02:37 PM
Default Re: Broken grounding point screw
Don't see why not.
Old Nov 5, 2016 | 07:07 PM
Steve Jr's Avatar
Just drill out the bolt you snapped off. Do you know what a "easy out" is? Drill a hole in the broken bolt, use that tool and remove. Next time remember, "that's tight enough"...we've all done it!
