Spoiler deploy no start 2004 crossfire help
Old Mar 17, 2017 | 09:07 PM
ramiusxxx's Avatar
Default Spoiler deploy no start 2004 crossfire help
I have a 2004 coupe with 20,000 miles. I don't get to drive it much as you can see and lately I am unable to start the vehicle. I turn the key I have power and immediately spoiler deploys. Spoiler light blinks. If I can get the spoiler to retract and get the all clear beep it starts right up. Brand new battery. Had it tested at Chrysler they said it was the ABS/BAS/ESP. What can I do to get it running to get it fixed? If it doesn't start it doesn't go in gear or neutral. Please help.
Old Mar 17, 2017 | 09:11 PM
Default Re: Spoiler deploy no start 2004 crossfire help
If in fact your new battery is a good one, I would say you have bad connection somewhere. Spoiler up on its own is a sign of low voltage.
Old Mar 17, 2017 | 11:22 PM
ramiusxxx's Avatar
Just traded in the battery for a new one today. I know the spoiler deploy is the car telling you there is something wrong if i remember correctly. If I can get the dam thing to go down all the way and give me the all clear single beep it will start. Sure am glad it started after the warranty was up
Old Mar 18, 2017 | 09:40 AM
The car can be put into neutral or reverse, put a pencil down the rear of the shifter as explained in the owners manual.
CLICK
File Type: pdf
Old Mar 18, 2017 | 01:06 PM
Make sure you have the posts and clamps CLEAN. Also, a known problem is the negative terminal at the fender has been known to corrode and become quirky. Check all 5 of these items and post back here the results.
Old Mar 18, 2017 | 01:40 PM
KDW4Him's Avatar
So the car is able to start now but the spoiler won't go down?
Old Mar 19, 2017 | 04:14 PM
ramiusxxx's Avatar
No start, you turn the key spoiler deploys. Try to retract spoiler and it deploys itself again. no start.
Had it tested at Chrysler a while back and they told me my BAS ESP ABS was bad and needed replaced.
Im going to check the grounds as suggested hopefully tomorrow but so far nothing. Talked to Chrysler corp awhile back they basically told me to pound salt only in a nicer tone.
Old Mar 19, 2017 | 06:09 PM
KDW4Him's Avatar
Do you have the BAS/ESP light on? Are you voltmeter savvy?
Old Mar 20, 2017 | 11:37 AM
tighed1's Avatar
No start, spoiler deploys, ABS/EAS fault lights.
ALL symptoms of a bad traction control relay in the Relay Control Module.
I can refurbish the RCM for $30 (postage rates went up again).
Email me at
tighed1@hotmail.com
Old Mar 20, 2017 | 01:32 PM
ramiusxxx's Avatar
Email me at
tighed1@hotmail.com
Do I need to do anything special to pull the RCM?
Old Mar 20, 2017 | 02:53 PM
tighed1's Avatar
No tools needed. This link shows where it is.
https://www.crossfireforum.org/forum...-no-start.html
Old May 1, 2017 | 11:55 AM
Chrisjlyon's Avatar
Did this solve your spoiler issue?
Old May 1, 2017 | 03:08 PM
ramiusxxx's Avatar
I have not had the chance to work on it because of work. First chance I get i will pull the board and take a look at those three solder spots to see if the pins are exposed. Appreciate the help since Chrysler has refused to do anything for me.
Old May 2, 2017 | 09:04 AM
tighed1's Avatar
Open the RCM and turn the key to the RUN position. Relays 2&3 should be closed. Bet 2 isn't.
Old May 2, 2017 | 09:39 AM
This photo is obsolete and has been replaced.
Old Jul 30, 2020 | 02:13 PM
bc75's Avatar
I'm having the same problem. I jump started my car the spoiler went down. So i drove it around town spoiler came back up all lights on dash came on and it wont shift out of first. So i parked it bought a new battery. Still wont start spoiler is up and i cant shift our of park. I checked my cables and the rcm. Does anyone have any ideas?
Old Jul 30, 2020 | 04:23 PM
How did you check the RCM?
Old Jul 30, 2020 | 04:58 PM
bc75's Avatar
I took it out and checked to see if the relays were open. I just tried to start it it fired right up then the dash lit up again. I shut it off now it wont start.
Old Jul 30, 2020 | 05:08 PM
bc75's Avatar
It just started again but the spoiler will not go down. My ABS BAS and ESP lights are on and it wont come out of park. Do you think it could be my RCM? last month i put a cam and crank position sensor on.I hooked my code reader im getting P0600.
Old Jul 30, 2020 | 06:31 PM
bc75's Avatar
When the car starts number 2 relay closes when it doesn't the relay stays open.But the lights on the dash stays on and will not go in gear.
