Brake Lever Cover
Old Mar 21, 2005 | 11:38 AM
DFWSBR's Avatar
Default Brake Lever Cover
Has anyone removed the brake lever cover? The manual doesn't give a great description on how to go about doing this. They simply say lift up and pull off.
I need to remove it to get the center console removed. I want to mount some bluetooth hardware under it.
Thanks -
Old Apr 29, 2005 | 01:36 PM
DFWSBR's Avatar
Default Re: Brake Lever Cover
Anyone? Come on. Someone has had to have removed this before!
Old Apr 29, 2005 | 02:29 PM
brittt1's Avatar
You just tug that bad boy with enough force and it slides off, put a little washing liquid on it when you're done and it will slide back on easy.
Old Apr 29, 2005 | 02:47 PM
DFWSBR's Avatar
I tugged the hell out of it. Nothing. Is it the rubber outside that slips off, or is it the entire handle?
Old Apr 29, 2005 | 04:25 PM
brittt1's Avatar
just the rubber, the rubber sits on metal...you really do have to pull but once it budges a little it comes right off. You could try sticking a small flat stong piece of metal between the rubber and the metal to pry it away a little, but be careful.
Old Apr 29, 2005 | 04:36 PM
DFWSBR's Avatar
Yeah, that's what I tried. I even used two little screw drivers and slid them way down the rubber side of the handle in attempt to break it free. Perhaps it was too hot. Perhaps the Texas heat melted it on!
I was tempted to just cut the rubber handle off. I wanted to look into the cost of replacing it though. I ended up working around it and gave up on the whole idea. I was still just kinda wondering how it was done.
I'll give it another shot after running the AC for a while.
Thanks for the feedback!
oldbiff
Mar 19, 2023 11:37 AM
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
RiderJC
Sep 7, 2015 11:19 PM
williammt
Sep 6, 2015 11:23 AM
