Differential swap
Old May 12, 2017 | 01:21 PM
gblack32's Avatar
Default Differential swap
Does anyone know how long/difficult/much it should cost for a shop to do a straight up differential swap? Wanting to get my new 3.27 gears with wavetrack installed but getting varying answers on time it would take and pricing. Any insight would be helpful
Old May 12, 2017 | 04:46 PM
Default Re: Differential swap
1.what car do you have? srt or limited std or auto?
2. does the new 327 have the wavetrac in it ? and would be a simple swap ,,3 hours @100 per hour, add oil,, add tcu and testing 4 to 5 hours.
3 remove your diff ,,install wavetrac in it anywhere from 4 to 10 hours because getting the backlash set.
4 if your car is a 2004, you need one piece axles .
cost, ??
Old May 12, 2017 | 08:49 PM
gblack32's Avatar
Hey jim. Car is srt. The wavetrack is already in it. But the dealership is estimating 14hrs labor and I thought it seemed like a lot for what I thought was a simple plug and play swap but wasn't sure
Old May 12, 2017 | 10:32 PM
you have the tcu correct?
look for a shop that works on Mercedes euro cars , they are all similar, you could call a few performance shops and see what they would charge. . you can change the tcu, it is under the carpet on the pass side, just unbolt the 307 ,,unplug the 307 tcu and plug in the 327,, tag them as they look the same.
who did you get the rear and the tcu from?,
to do it your self, you need a lift, ----------
1 drain the oil
2 take all the arms loose, not the lower control arm,
3. take the brake caliper off the rotor, tie it up.
4 with the shock loose from the lower control arm
5 remove the axle nut at the rotor
6 pull the rotor down and to the left or right so the axle will come out of the rotor
7 remove the bolts on the driveshaft center bearing let it float
8 remove the bolts on the driveshaft flex coupling, pry the drive shaft out of the diff.
8 put a brace under the diff or have someone hold it up as you remove the two bolts at
the rear of the diff, remove the bolt at the front of the diff.
9 remove the diff.
10 reverse the steps to reinstall the diff. use only the oil recommended by unatrx
note the srt6 and the limited use two different yokes. see here
https://www.crossfireforum.org/forum...ferential.html
Old May 12, 2017 | 10:56 PM
gblack32's Avatar
Diff is originally from grip grips car I bought it from reddog. Tcu was done by Rudy as far as I know
Old May 13, 2017 | 08:32 AM
then you should be good to go.
