driving home and all my dash warning lights
Old Jun 15, 2017 | 08:32 PM
roychez's Avatar
Default driving home and all my dash warning lights
I was driving home and all my light lite up. My car was running but I hand no speedo, all my warning lights were on. it ran like normal but the rear wing did not go down when I stopped.
after I turned the car off it would not turn back on.The radio worked but no crank. I disconnected the battery hoping maybe something would reset. no such luck..
please i need help.
Old Jun 15, 2017 | 09:16 PM
roychez's Avatar
Default Re: driving home and all my dash warning lights
I went out and started the xfire limited all the lights were on again. I turned the xfire off and tried to start it again but nothing....
Old Jun 16, 2017 | 08:32 AM
roychez's Avatar
After reading other people post with similar issues I think I`ll start with the RCM. Any advice would be greatly appreciated.
Old Jun 16, 2017 | 09:33 AM
roychez's Avatar
maybe this?
Old Jun 16, 2017 | 09:44 AM
That RCM for sure needs re-soldering on those 3 lower left connections,
as well as several others I see.
Old Jun 16, 2017 | 12:07 PM
roychez's Avatar
soldered all the spots that looked bad. reinstalled in the car I had an issue with wing not staying down, but that eventually cleared. I drove about a half mile and the same issue came back.
I have a question about the relays, should they all be closed when attempting to start, or will some be in open position ?
Old Jun 16, 2017 | 01:35 PM
the engine and fuel pump relays should be closed.
RCM relays
Old Jun 16, 2017 | 04:01 PM
RCM relays
That is an obsolete photo of the RCM another one exists on here.
If I remember I'll add it here.
Old Jun 17, 2017 | 09:53 AM
roychez's Avatar
the relays look like a tough job to replace. Should I just purchase another one?
I think that will resolve the issue. Any thoughts?
Old Jun 17, 2017 | 12:23 PM
If you cannot solder well or your skills have deteriorated, send it to member tighed1 ( https://www.crossfireforum.org/forum...o-start-2.html post 1047) for a rebuild.
