how do you completely disable traction control?
Old Feb 3, 2018 | 02:19 AM
wcschuyler's Avatar
Default how do you completely disable traction control?
on a mission to find a way to completely disable the traction control on my 04 n/a, ive read other threads that said to remove I think the 17&18 fuses but those are non existent on 04 models as far as I know(at least on mine), someone else said its on the bcm under the shifter. id like to wire a switch to it so I can turn it on and off, so does anyone have any insight into this which fuse or wire/plug I need to access to completely turn off the traction control? does anyone know where I can find a schematic for the bcm? thanks.
Old Feb 4, 2018 | 12:45 PM
NeedsWings's Avatar
Default Re: how do you completely disable traction control?
if you are trying to drift the car you will want to unplug the yaw sensor
Old Feb 4, 2018 | 07:49 PM
waldig's Avatar
Talking Re: how do you completely disable traction control?
My yaw sensor is connected to a switch for that purpose, its located rearward of the shifter under the carpet. Woody
Old Feb 5, 2018 | 06:02 AM
wcschuyler's Avatar
ooh nice any pics or something I can go off of would be greatly appreciated!
Old Feb 5, 2018 | 04:54 PM
alexdc's Avatar
will tc still kick in?
Old Feb 5, 2018 | 05:29 PM
NeedsWings's Avatar
hahaha...... no
Old Feb 7, 2018 | 02:40 AM
alexdc's Avatar
hahaha...... no
ABS will still work?
Old Feb 10, 2018 | 02:32 AM
alexdc's Avatar
Now I'm confused. I thought there was no way to totally disable traction control/stability control without pulling a fuse and disabling both + abs.
Can someone clarify? I definitely want to disable tc/stability but keep abs. Not on the streets.
Old Feb 19, 2018 | 04:17 AM
wcschuyler's Avatar
Theres no fuses on my crossfire
Old Feb 19, 2018 | 03:55 PM
Veerry interesting!!!
Old Feb 19, 2018 | 05:31 PM
Wonder how that one made it off the line and through QC ?
Old Feb 20, 2018 | 01:38 AM
alexdc's Avatar
Nobody is aware of this?
Old Feb 20, 2018 | 03:52 PM
JEFASOLD's Avatar
I have lots of 'em, I'll loan you a few!!!!
Old Feb 23, 2018 | 04:16 AM
wcschuyler's Avatar
the mentioned fuses related to the TC...
Old Apr 3, 2018 | 06:35 PM
alexdc's Avatar
So the yaw sensor in the steering wheel needs to be unplugged?
Can we get more info on this. I wonder if we could make a module to fool the system.
Old Apr 3, 2018 | 08:19 PM
The yaw sensor is NOT in the steering wheel, it is under the center console.
Old Apr 4, 2018 | 12:32 AM
alexdc's Avatar
But will unplugging the sensor let you spin the tires as much as you want? with tc off?
will any light come up on the dash?
Old Apr 4, 2018 | 04:43 AM
No personal experience, but others may know.
The ABS communicates with it via CANBUS and there are a dozen or so P codes listed,
so I imagine at least a CEL light and probably ABS too.
Old Apr 10, 2018 | 12:31 PM
150MPH's Avatar
No idea how this particular car is set up but usually the ABS and TCS are using exactly the same sensors and same computer so disabling TCS by pulling a fuse will probably also kill ABS.
Old Apr 11, 2018 | 02:04 PM
waldig's Avatar
I have a switch on the yaw, when it is on the abs light is turned on, why do you want spin your tires?
I had a phantom grip and later went with the wavetrac (sp) for traction!
Woody
