Telescopic wheel lock stops car from starting?
Old Apr 9, 2018 | 08:55 PM
English Rob's Avatar
Default Telescopic wheel lock stops car from starting?
Can anyone enlighten me on this issue
1st happened couple of months ago car cranks no start I noticed that the telescopic wheel light was on (never seen it before I had the car 7 years) pulled the lever out and pushed it back light went off car started
this weekend it did it again however couldn't reset towed home removed lower dash adjusted the cable on the steering latch car started light on at start then off
Today car quit on way home from work
light on crank no start adjusted cable again lot of jiggling and pushing and pulling finally got it to start it then quit again 500 yards from home.
The latch is operating the micro switch and I have adjusted the wheel every which way
cranks will not start
HELP
Old Apr 9, 2018 | 09:36 PM
KDW4Him's Avatar
Default Re: Telescopic wheel lock stops car from starting?
HELP
I have moved the steering wheel with the engine running with no issues. Sure your not vibrating something loose? What if just banging around causes the same symptoms.
Old Apr 9, 2018 | 09:54 PM
I have pushed and pulled on wheel when running I can't replicate problem
I am having car towed now I am going to dig into it tomorrow I have a feeling something is grounding out but I also wonder if the micro switch that operates the indicator light is open and is somehow grounding the ignition circuit?
Old Apr 10, 2018 | 03:02 PM
UPDATE
Changed the CPS car appears to be good now
Thank you all for your input
RoadsterBabe
Jan 31, 2022 05:14 PM
burnzboy2
15
Nov 1, 2015 02:17 PM
2006Crossfire
Sep 22, 2014 05:08 PM
doug5639
Sep 11, 2011 10:19 AM
andrew
Other Cars Etc
Oct 24, 2009 05:42 PM
