What did I do?
Old Jun 2, 2018 | 12:51 PM
FIXRE's Avatar
Default What did I do?
This will be rambling but I'm trying to give as much information as I can:
The car is a 2006 roadster with 31000 mi . Due to my health issues The car has been sitting up for a little over a year. I would infrequently start it and let it run for a while sometimes driving it around the neighborhood. The other day it wouldn't start with a jump. I noticed the battery was well past due for replacement. I bought a new batter, installed it and took it out for a ride lasting about forty minutes not driving over forty miles an hour. It performed just fine, no issues. Yesterday I thought I'd go out for breakfast in it. It started fine and until I stopped at a red light all seemed well. When I took off from the light the car seemed to be in low gear, thought maybe I had accidently tapped the gear shift to first or second gear but it wouldn't up shift. I pulled over and put it in park and when I tried to put it back into drive the gear shift wouldn't budge. I shut the engine off and then restarted and it slid right into drive. I took off but with very low power and the spedo wasn't working. Made a U-turn and went home and parked it in the garage. This morning I went to start it and the dash lit up but engine would not start.
Any one have any thoughts on what could have happened?
Old Jun 2, 2018 | 03:15 PM
Steve Jr's Avatar
Default Re: What did I do?
Frist thing to do is check all your grounding points. Look at the cable itself , sometimes corrosion can build up inside the cable. Then at the connection on the fender well. Then to the engine. Pizzaguy has a checklist for using an amp meter to ensure proper grounding.
Old Jun 2, 2018 | 04:28 PM
Sounds suspiciously like a transmission conductor plate to me.
No speedo ( speedo pickup is on conductor plate )
staying in low gear, refusing to shift ( limp mode )
It could just be low fluid, check the electrical connector front right side of tranny for leakage signs.
Now THAT sounds like an RCM ( Relay Control Module ) issue, assuming "would not start" means engine would not turn over.
Old Jun 2, 2018 | 06:12 PM
Try and cut out the guess work and get any codes read.
saskins
Sep 5, 2004 05:52 PM
SeaXfire
Apr 9, 2004 09:41 PM
ptenthus
Mar 19, 2004 03:20 PM
Leviathon
Feb 5, 2004 11:59 AM
texex91
Aug 28, 2003 10:11 PM
